There are 2 types of volume for the keypad
The voice menu volume can be changed for each kleypad by pressing 7 for Volume in the voice menu, enter a volume between 0 to 100 (but avoid numbers above 50 as it causes distortion and may overstress the speaker)
The Announcement volume is different. This means the volume of the announcements eg Security Off, Away, Night Mode, Alarms, zones which are announced on the keypad when events or alarms occur
The global voice annnouncement settings are in Configuration > Voice Settings > Keypad Announcement level
Yo9u can enable or disable voice announcement in the KP04A menu (Press F0 and then press and hold * key). Press * or # to scroll the options until you get to Keypad Broadcast Enable/Disable). You can disable announcements "permanently" using this method eg keypad in the babys rooom
You can enable or disable announcements on any keypad using the action
"keypad (ID" Broadcast Disable or Enable as in the attached screenshot
You can use a Time program or other event to enable or disable announcements on any keypad or all keypads (use ID=0 for all keypads)
However this is enable or disable, not adjust the volume of the keypad
Attachment: KPanounce.JPG (Downloaded 23 times) Last edited on Thursday Apr 26th, 2018 02:17 am by slychiu
