KP06 issue
 Posted: Thursday Nov 21st, 2013 08:46 pm
hinis
I was using two keypads, one KP04 and one KP05 without any problem. I replaced these keypads with two keypads KP06. I have a problem with the new keypads. When some of the zones are triggered instead of the programmed name of the zone being displayed on the LCD, it is displayed  LOUNCH LOUNCH
LOUNCH LOUNCH
The speakers announce the correct phrase during security check.
I did not have this problem with the KP04/KP05.
When I update the text of the keypads (*1) or when I reset comfort, the problem is resolved to appear again later.
 FIRMWARE VERSIONS
7.033 COMFORT II ULTRA
6.007 KP06
I have updated to 7.040 and now to 7.042 without any changes.
The language I am using is Greek.
Any solution?
 Posted: Friday Nov 22nd, 2013 01:20 am
can you send the cclx file so we can test
Is there a green vocab file that you are using? Did you have to make any changes to the config files in order to use Greek?
Please send these to support@cytech.biz
 Posted: Saturday Nov 23rd, 2013 03:32 pm
marinoss
You need the Greek vocubulary file and the vocust.cfg. I will email you those with some instructions for the Greek setup.
 Posted: Friday Nov 29th, 2013 08:58 pm
hinis
I have used the vocust.cfg, vocab.cfg and the customised Greek word list that Marinos from BIAS Ltd has sent me in order to configure the COMFIGURATOR for the Greek dictionary and then I re-transferred the cclx file to Comfort. The problem was solved.
MANY THANKS FOR THE SUPPORT.
 Posted: Tuesday Apr 1st, 2014 01:20 am
avney88
I am having a similar problem as hinis with the activated zone status that is being shown on the keypad (KP-06). I am using the standard "English residential" vocab.
Originally posted under "responses and actions" but then found this, so sorry for the duplicate post.
When I first upload the configuration all triggered PIR's will show correctly on the panel, However, after some time the display will revert to showing "kitchen kitchen kitchen kitchen " no matter what PIR or door is triggered.
I have checked the config thoroughly but cannot see any errors. Is this a bug in the system? and if so is there a work around?
I am using version 3.7.8.0 of the configurator.
On another subject - should I be able to ping the comfort from my PC via the eth3 module? I am managing to communicate with the Comfort via the configurator without any problems, but was just wondering if ping responses were blocked somehow?
Thanks in advance.
 Posted: Thursday Apr 17th, 2014 08:51 am
This problem has been fixed in KP06 firmware 6.008, see the announcement here http://www.comfortforums.com/forum114/3769.html
 Current time is 03:01 pm
