KP06 id problems on first power-up
 Posted: Monday Aug 12th, 2013 07:41 am
Vangelis
Hi there,
Using Comfort Ultra II ver 6.002
Powered up after first fix installation..
All sensors connected
Backup Battery
No BellBox (SRNTMP shunted)
No phone line (need to disable this in the menu)
2 x KP06 (ID1 & ID2)
When first powered up I received the following msg on both keypads
"Wrong Text push *1 together"...so I did this and got the msg
"Engineer sign-in option is off"
After a bit of playing I worked out both KP06 id's were the same so set the first to ID1 and the second to ID2 by long hold of * button
They both reboot and KP06 with ID1 comes back and shows the time and Security as off
KP06 with ID2 just shows ID#2 Ver6.002 and freezes.
I reset the motherboard (via button) and both KP06 reboot but come back the same. I can fully interact with the KP06 (ID1) but not the other
Reversing the IDs gives the opposite result where the other KP06 comes alive.
I noticed that for KP06 the firmware needs to be at least 6.005 so not sure if this is the cause.
Any ideas??
Also can you let me know the option for disabling "phone trouble" in the keypad menu as I haven't connected my Laptop to it yet.
Vangelis
 Posted: Monday Aug 12th, 2013 12:58 pm
If you have not programmed Comfort then the number of Keypads  is 1 so the 2nd keypad will not be polled
I suggest you upgrade to the latest Comfigurator (3.6.8) and upgrade the KP06, UCM  and Comfort firmware to the latest  version 7 as shown in http://www.comfortforums.com/forum92/3400.html
It is really easy now, and it will save you a lot of time and problems later on
Do a scan for modules which will detect your Keypads. Then you can check "Ignore Line Cut" and write to Comfort
If you really need to use the keypad to ignore line cut go to Engineer Menu > Locations Menu and enter location 40 = 82 and reset Comfort
 Posted: Monday Aug 12th, 2013 01:29 pm
Vangelis
Thanks, will do that.
Any issues with upgrading the ETH2 UCM module whilst your connected?? If the upgrade fails then surley you will lose comms to the whole system??
 Posted: Monday Aug 12th, 2013 02:11 pm
No if there is any problem with the upgrade you can just repeat it. The connection to the Ip address and port will not be affected
 Posted: Wednesday Aug 28th, 2013 07:08 pm
Vangelis
Managed to upgrade both KP06 to 6.007 but after a power cycle I am seeing "Keypad NOT polled" on KP06 (ID2).
This is the furthest keypad from the main unit (say 10 meters) but I am using shielded twisted pair.
Comfigurator sees the KP06 (ID2) and its firmware version when scanned, but the keypad itself is still showing that it's not polled.
As a side note when I hold down * I can only change the keypad ID and am not able to cycle through the keypad menu (in order to try a factory reset) - holding down the * for 6 seconds doesn;t work either...
I know there is a bug mentioned about having two KP06 and setting their IDs when the power is on, but I have done them in sequence and still no good.
Thoughts?
 Posted: Thursday Aug 29th, 2013 03:42 am
After you scanned the modules and found the 2 keypads, did you write to Comfort? If you do not write to Comfort, the number of Keypads is still 1.
Scanning will set the correct numbers of modules detected in Comfigurator but unless you write to Comfort, Comfort does not know it
 Current time is 01:58 pm
