Posted: Wednesday Sep 5th, 2012 08:45 am |
TheMax74
Posts: | 247 |
Hello, i've a problem with a brand new keypad KP04.
The green led (security off) has newer worked.
The red ARM led works properly, but when i disarm, the green led stay OFF.
Reset doesn't work. Compete power off and restart, doesn't work.
ALL other 3 keypads works flawlessly.
I suspect a defective LED.
Is there some other things to search for, maybe in the keypad board itself (undocumented jumper, etc..)?
Thanks.
Posted: Thursday Sep 6th, 2012 01:50 am |
If you reset the keypad or cycle power all leds should momentarily turn on
If the green led does not, then it shows it is faulty
Posted: Monday May 26th, 2014 12:58 pm |
dipo_19
Posts: | 5 |
all the lights on the keypad is off only the home led light is flashing.
Posted: Monday May 26th, 2014 01:05 pm |
dipo_19
Posts: | 5 |
all the lights on the keypad are off only the home led light is flashing,also the telephone connect to the security system is given tamper alarm what can i do?
Posted: Monday May 26th, 2014 01:12 pm |
hendy
Posts: | 221 |
Home led flashing means there is a trouble alarm, most likely to be phone trouble based on your description. Check the phone line and if it is okay, try to sign in on the keypad to clear it.
Posted: Monday May 26th, 2014 07:38 pm |
dipo_19
Posts: | 5 |
no display on keypad and all the lights are not coming on only home light is blinking.
Posted: Tuesday May 27th, 2014 05:52 am |
First, please do not post on more than 1 place. We will answer wherever it is
Which keypad model is this, KP01, KO03, KP04, KP05, KP06, KT03
What is the serial number and where did you buy it from and when?
Please answer in reply to this, and do not post a new message elsewhere
