Posted: Monday Mar 28th, 2011 03:22 pm |
m.khairy
Posts: | 32 |
i have a kp04 , when i communicate it with the system the message that appear on keypad is
keypad communication failure
and the system doesn't work
i tested the cable , it's good
and isolate all i/o
however the problem is still
Posted: Monday Mar 28th, 2011 04:02 pm |
This message means the keypad is not communicating with Comfort either because the KA/KB wires are connected or the ID on the keypad is not set correct
If there is only 1 keypad then the ID should be 1
ie the shunts A B C should be connected
The Number of Keypads in Comfigurator should match the number of keypads in he system and each ID should be set unique
Posted: Tuesday Mar 29th, 2011 07:49 am |
m.khairy
Posts: | 32 |
Thanks for replying
But,
The KA/KP wires are connected
i have only 1 keypad and the ID is 1
The number of keypads in comfigurator is 1
The problem is still
Posted: Wednesday Mar 30th, 2011 12:21 am |
hendy
Posts: | 221 |
How long is the cable connecting the KP04 to the Comfort panel?
Try connecting them with a short cable e.g. around 1 meter and see if it makes any difference?
Could it be that the KA/KB connection is reversed i.e. KA goes to KB and vice versa?
You have mentioned the keypad ID is 1 so all shunts A, B, C, D have been ensured to be closed or shunted?
And one more thing, when the Communication Failure displayed on the KP04, what Keypad number is displayed? Is it Keypad 1 e.g. "Communication Failure Keypad 1" or some other numbers?
Posted: Wednesday Mar 30th, 2011 03:40 am |
Posted: Thursday Mar 31st, 2011 12:18 am |
hendy
Posts: | 221 |
Have you tried with a short cable?
Posted: Thursday Mar 31st, 2011 07:06 am |
what else is connected to KA KB? are these other modules working?
Can you connect a UCM to Comfort and communicate?
What are the state of the red and green leds on Comfort PCB
Posted: Wednesday Apr 6th, 2011 11:36 am |
m.khairy
Posts: | 32 |
The problem was in the firmware update ,
when i updated the firmware the keypad worked correctly
Posted: Wednesday Apr 6th, 2011 03:00 pm |
I think there may have been a firmware upgrade attempted before which was not successful which caused the system to be inoperative.
