Posted: Thursday Nov 20th, 2008 11:09 pm |
tomekajja
Can UCMO5 (version 5.156) be used to download the word list to KP04? The manual says UCM01 (version 5.72 and above).
I need to do this because the KP04 shows wrong words for the zone activations.
I am using a Comfort I board with firmware ULTRA 4.230.
Also when down loading the word list using the "LCD Keypad Language customization software", the instruction say disconnect the KA/KB from the main board J15 and connect the UCM KA/KB to Keypad KA/KB.
Does this mean I power the Keypad and UCM and connect the keypad KA/KB directly to the UCM KA/KB and then download the software?
Tom
Posted: Friday Nov 21st, 2008 07:04 am |
Posts: | 5499 |
Online
Yes the UCM05 is an advanced version and a replacement for UCM01 so it can be used for this purpsoe
You are correct, power the keypad and UCM using the existing wires and disconnect KA/KB from the Comfort and connect it between UCM and keypad to do the download
It is not a simple procedure. Consider upgrading to Comfort II by buying a Comfort II PCB only. This will allow you to benefit form all the new features and those to come
Posted: Friday Nov 21st, 2008 08:58 am |
tomekajja
I have followed procedure on the KP04 manual but I get login failure even if I use user or engineer code.
Please help
Posted: Monday Nov 24th, 2008 12:31 am |
leonchue
Posts: | 71 |
I suspect that you did not have KA/KB connection to the main board. Please check that.
After signing in, then you will be prompted to disconnect KA/KB from main board
Posted: Monday Nov 24th, 2008 03:10 pm |
tomekajja
I think it tried this but will double check and try again.
Tom
