Posted: Monday Sep 25th, 2006 08:35 am |
garym999
Some ideas for future versions of comfigurator feel free to chip in...
I do appreciate that some of the requests, although being borne from the use of Comfigurator, may well have firmware implications for comfort but lets start the list.
- Connection method/details stored per CCL, serial, ip, ip address etc.
- When coding responses, ActionBuilder should have a button to list all Reponses as sometimes it can be difficult to find the command you want.
- Action builder should have the rem(ark) option included.
- Be able to move responses up or down the code window on a line by line basis.
- Redesign the responses section such that the list only contains barebone code (responses) to have a functional security system. From there any changes made should be highlighted in a different colour. This will make things clearer. Then perhaps we can have a drag and drop function such that stock code examples, custom codes etc. can be dropped in as required. Could make for easier code sharing via forums etc. And make programming multiple systems with similar code more efficient.
- Response Window: Would like to be able to choose the default sort option (e.g. sort by name, sort by response no' etc)
- Timers: Have two types, what we have now together with Timers that have on and off times with on & off responses. I know we can code this already but it would just be a more logical. Especially from the clients perspective when using the keypad.
- Introduce repetitive events (timers), once a minute, once every 10 sec's etc. I know we have the hourly event and can code other durations but it would be easier to have this option already there
- Integrate real-time monitoring and control for debugging (similar to wizcomfort facilities), monitor outputs, monitor & simulate inputs, send X10 commands and IR codes etc. Perhaps these should appear in a separate monitor window
- Do function... Expand the commands options such that it can, do responses, do outputs, do Dynalite, do x10 etc. all directly. Again this would make coding more obvoius and easy to understand.
- Be able to download, sounds, mp3s etc. for reminders etc. Ideally be able to get Comfort to play these directly as alarm types (a selection of nice doorbells)
- If the above cannot be done (which I suspect would be the case as there is likely to be a lot of work there) have an emulation/construction tool for the "sound types" so it is easy to make changes and test before downloading.
Thats my starter list, I'm sure there will be more to come.
Posted: Monday Sep 25th, 2006 10:25 am |
yanza
Posts: | 12 |
The YANZA "My Home" software can be connected to Comfort and monitor bus information in real time for diagnostic purposes.
See http://yanza.com for details of all our products.
Posted: Tuesday Sep 26th, 2006 04:51 am |
dcrera
For me,
I just need full support for 15 Scs/Rio's asap.
Sorting alphabetically on the response list would also be good.
Posted: Monday Nov 6th, 2006 04:58 pm |
garym999
Writing to the event log would be handy on several levels, fault finding, logging events etc. Another request for the future I guess.
In comfigurator it might appear as Output Action/Write to event log/text value or flags, counters, input state output state etc.
Posted: Wednesday Feb 21st, 2007 09:19 pm |
on4cet
Posts: | 23 |
I wonder if it's possible to design a program which fully simulates a comfort panel, so you can test programs before uploading to comfort ... In that case, you know what SHOULD be happening ...
Can it be done, and if yes, will it ever be done by someone ?
Kind regards,
Bart
Posted: Thursday Feb 22nd, 2007 03:49 am |
Posts: | 5493 |
Thanks for the suggestion.,
That would be a difficult task and it is quite unlikely that we could do it as it would involve two parallel tracks for development of firmware/software
The best way to simulate would be to use an actual comfort on the bench, with Zone Test switches on the inputs and Test Lamps on the output
Posted: Friday Feb 23rd, 2007 09:22 am |
Patrick
For the Network IP Address setting, I think it is better to allow host name instead of just IP address.
Posted: Saturday Feb 24th, 2007 07:12 pm |
on4cet
Posts: | 23 |
Someone said to integrate real-time monitoring like wizcomfort ... I was thinking, is there a way to see what comfort has in its queue ?
If you run one response after xxxx minutes, you know what you may expect, but if there are many responses like that, it might be nice to see what things are waiting to be runned ...
Just my 2 cents ...
Bart
Posted: Tuesday Feb 27th, 2007 04:21 am |
Thanks for your suggestion
This would be more difficult to implement than the degree to which it would be useful to you
You can check what timers are running in Comfort using the Do Action command (Get Timer, Timer number). This tells you if the selected timers are running and thus which responses will run at the end
Posted: Wednesday Feb 28th, 2007 07:52 am |
on4cet
Posts: | 23 |
Ok, if it can't be done, it is so ...
But I see in the current wizcomfort, that you can view output & input status, so if you would implement a button wich generates a do action get timer for ALL the possible timers, you are half to the solution i guess
But is was just something that crossed my mind ...
Kind regards,
Bart
Posted: Friday Apr 20th, 2007 07:30 am |
dcrera
How about giving the user the option to add their own help text to the standard Comfort help text.
Posted: Saturday Apr 28th, 2007 05:18 am |
garym999 wrote: Some ideas for future versions of comfigurator feel free to chip in...
I do appreciate that some of the requests, although being borne from the use of Comfigurator, may well have firmware implications for comfort but lets start the list. I have also made a note on the items on your list for the next version. Some may be possible, some not
regards
Posted: Saturday Apr 28th, 2007 05:28 am |
dcrera wrote: How about giving the user the option to add their own help text to the standard Comfort help text.
I dont think that is feasible, no software product has this capability. I dont see there would be much benefit
Posted: Monday Apr 30th, 2007 04:44 am |
dcrera
You are so wrong, we have an ERP system that does this with no fuss.
Anyway, because no other HA system has done this does not mean it is not feasible.
Do you want to lead or follow ?
Posted: Monday Apr 30th, 2007 04:54 am |
Sorry but it is not a matter of leading or following.
We cannot implement somethign just because others have this or do not havce this
We need to justify the timne and resources spent on things which are most useful
We do get lots of suggestions which are appreciated but not all can be implemented
I do not see any big benefit in being able to add your own help test compared to the difficulty of having this feature. The requirements of ERP systems are not the same as those of HA systems
regards
Posted: Monday Apr 30th, 2007 05:41 am |
dcrera
Then say it like it is ... 'we do not have the time nor the resources to implement this feature.'
After all this is a wish list
Posted: Monday Apr 30th, 2007 11:50 am |
17th Post |
All right.
We do not have the time nor the resources to implement this feature, mainly because we do not see the benefit to many users of doing so. As our resources are limited, spending time to develop one feature means giving up something else
I hope this is a satisfactory explanation, and does not offend.
regards
Posted: Monday Apr 30th, 2007 01:50 pm |
18th Post |
