Comfigurator 2.1.0 has been released as of August 2006
Bug Fixes- Handle missing default template file saved in Registry
- Use correct defaults for Vocab and Voice settings when converting to different DspType
- Save currently selected combobox value if exiting while editing
- Allow right-click to terminate combobox editing
- Fix problems exporting/importing responses with references to IR codes
- Sort responses with numbers > 999 correctly
- Fix problem reading file with uncommented action codes in response
- Increase download timeout to cater for delays due to high Comfort activity
- Ensure number of timers is adjusted correctly when converting between filesystems
New features - Support for branch action codes, removing restrictions on use of IF/THEN/ELSE
- Support ANNOUNCE WORDS action in Response Wizard
After installation, please download the attached file eventlog.cfg into the Comfigurator folder
The eventlog.cfg file holds the definations of the events in the evnt log. The latest event log configuration file contains definations of new events 27 to 30 concerning User code change and delete and GSM trouble and restore which were not in the release version of Comfigurator
Attachment: eventlog.cfg (Downloaded 7 times)
