Nest thermostat
Poll
Comfort to Nest. Yes or no
View Results
 Vote
 Posted: Tuesday Aug 12th, 2014 06:48 pm
Daylehouse
Hi, Any plans to add Comfort integration for the Nest thermostat?
API program here,
https://developer.nest.com/
Nest has a home and away feature which would fit perfectly into the Comfort alarm system setting the Nest stat to away when the alarm is in away mode. Also if Nest smoke alarms go off it would be great if Comfort could turn on the lights / dial out alert etc.
Cheers
Dayle
 Posted: Wednesday Aug 13th, 2014 02:53 am
tman
You'll most likely need a PC to talk to the Nest servers using their API and also Comfort. Getting it working with just the UCM + ETH03 by itself is going to hard.
You'd need to implement Firebase or REST streaming to talk to the Nest server, a JSON parser to decode the reply, OAuth 2.0 for authentication and then the actual Nest API. You'd also need to store all the configuration necessary like the OAuth tokens. Doing this all on a PC is fairly simple but trying to shoehorn it into the little PIC in the ETH03 is going to take significant effort.
I've got Nest Protect smoke alarms and a Nest thermostat myself so have partially implemented what you suggest. I wrote an extra module for the software I wrote that runs on a server I leave on all the time. It doesn't talk to Comfort though but it is a nice idea to do so.
 Posted: Wednesday Aug 20th, 2014 05:24 pm
Daylehouse
Would be great if we could have a UCM that could support REST based APIs.
 Posted: Thursday Aug 21st, 2014 02:25 pm
Perhaps Tmans software could be extended to talk to Comfort via the UCM/ETH03 without much difficulty?
That would seem to be an easier way to do it
 Posted: Thursday Feb 16th, 2017 09:27 pm
mattbrain
You should be able to do what you wish via http://www.comfortforums.com/forum136/
It is possible to associate nest devices with SmartThings and then build rules to interact with Comfort as required.
Thanks,
Matt
 Current time is 07:33 pm
