ComfortClient Release
 Moderated by: juwi_uk, Ingo
 Posted: Sunday Jun 14th, 2015 08:48 pm
I've enhanced a few things since the release so issuing this Maintenance Release.
Fixes:
  • Object Clone in Floorplan Editor did not deep clone Action Points correctly.  They’d be still tied to the source object until the editor was restarted (at which point they’d fully separate).
  • Print Preview, Print & Object Matrix menu items did not enable/disable based on lock/unlock UI and configuration menus persistence settings respectively for ComfortClient.
  • The Installer now creates an empty “Connectors” folder; this prevents the user data folder migration logic from erroring on first run after install.
  • Refactored the MRU list code in FloorplanEditor for better storage in the registry.
  • Cannot update the ShapeFactory if its DLL is open;  occurs when starting Floorplan Editor from within ComfortClient as the latter already has this file open.  The update will be deferred to the next restart of ComfortClient or ignored depending on the user choice.
  • Improve handling of messageboxes during startup so that they are always topmost rather than at times hidden behind the splashscreen.
  • If you choose NOT to apply a ShapeFactory update it will not be prompted further until the next version becomes available.  To reset so that this update is prompted again, use the “Restore Updater Checks” menu item on the ShapeFactory menu.
  • Minor help tooltip fixes and additions.
 Current time is 08:17 am
