Posted: Sunday Jun 8th, 2014 03:28 pm |
For all registered users I'm pleased to announce a new maintenance release; 4.1.3.5.
This is a minor release just to fix a couple of issues found in the last version.
The full list of changes is below.
Hope you enjoy.
Bug Fixes/Changes
- Cbus1 format Template ClickResponses did not decode correctly in Floorplan Editor object properties when the Action was of “switch†type; the Application would default to “Lightingâ€.
- Fixed “Object not set to an Instance of an object†error in log file during load of Connector Services.
- During connection retries (Ethernet) the UI state is now changed to lock out any buttons/menu options that would otherwise try to use the failed connection (Send Command, System Information, Refresh etc).
New Features
- The Home Control menu now supports right-click on a node action to execute it.
Posted: Saturday Jun 14th, 2014 11:28 pm |
It's a bit disappointing there hasn't been much of a take-up for the latest versions of ComfortClient amongst the community.
I assume you are not interested in supporting 3rd party integrations then!
That's a shame as it does have a bearing on my commitment and enthusiasm.
