ComfortClient
 Moderated by: juwi_uk, Ingo
 Posted: Thursday May 9th, 2013 01:11 pm
For those of you using ComfortClient, I've posted a new maintenance build which fixes the following issues:
• Disable red “X” button on Lock/Unlock window.
• Activity Tabs could be cleared when UI was locked.
• Removed redundant menu shortcut key that launched Smartfit mappings.
• Added some missing shortcut keys for Information menu.
• Update Check is now moved to a separate thread.
• CounterFlag objects only triggered to “ON” state on a received value of “FF” (255) instead of triggering at any value greater than zero.
• ComfortClient could fail to start if the optional DocumentFormat.OpenXml.dll was missing from the folder where ComfortClient is installed. This was caused by an over aggressive code obfuscation setting.
• ComfortClient would perform an update check twice at start-up.
You can check for updates in ComfortClient or download from the usual links.
Cheers
 Current time is 02:14 pm
