ComfortClient on Windows 8
 Moderated by: juwi_uk, Ingo
 Posted: Friday Oct 26th, 2012 01:44 pm
I've been developing and running ComfortClient for a couple of months now on Windows 8. It installs and works fine.
I am developing using visual studio 2010 at the moment.
There is one issue (warning) I am seeing on ComfortClient Uninstall; in fact you'll get 3 of them.
I believe it is due to the installer trying to delete shortcuts from the START menu; not surprising it might fail then as Windows 8 doesn't have a START menu anymore. It didn't complain on install though when it tries to add them which is strange too!.
I have this logged on the Microsoft forum but if you do install/uninstall on Windows 8 then you can safely ignore these warnings IMHO.
p.s ignore the version as this is just the version I was using when I snagged the screenshot.
Attachment: Win8Warning.png (Downloaded 52 times)
 Posted: Sunday Jan 6th, 2013 09:55 pm
This problem was acknowledged by Microsoft and it doesn't do this anymore so I guess a Windows 8 update has fixed somewhere along the line since it was released.
J
 Posted: Wednesday Jan 16th, 2013 12:02 pm
Still seems to be chundering along as an issue at Microsoft camp; see below if you are interested.
First was NVidia driver, now desktop.ini....
http://social.msdn.microsoft.com/Forums/en-US/winformssetup/thread/09f72e05-f43f-4e7e-81b6-f81c1b60dc6c?prof=required
 Posted: Sunday Feb 3rd, 2013 12:52 pm
mgfair
Hi Julian
Just downloaded this today.......good stuff! It works fully BUT I don't seem to be able to change the config file. You have to be logged in for the necessary dialogue box to enable you to change settings BUT when you want to change settings it asks me to log out!
 Posted: Sunday Feb 3rd, 2013 02:48 pm
Yes I added that feature for security. The option to edit the configuration only appears when you are logged on by default.
If you want to get to this menu when signed out then when you've signed in go to options and set "persist configuration menus" to true. Then in future it'll be permanently available.
Alternatively if you just want to edit floorplans you can of course also start up FloorplanEditor directly.
That should fix! Enjoy.
 Posted: Sunday Feb 3rd, 2013 02:58 pm
Ah, I've just re-read what you wrote.
Yep that could be a deadlock. You can still do the fix I advised and I'll fix in next version.
 Current time is 05:14 pm
