Comfort Automation/ Security System Forums > Software Applications > ComfortClient > ComfortClient / Plugins / Connectors / Addons
 Moderated by: juwi_uk, Ingo
 Posted: Friday Aug 6th, 2010 05:07 pm
I've started this thread as a landing zone for the latest posted versions of the ComfortClient and supporting applications. You can also download from my website at: https://www.futurehomesoftware.com ComfortClient: ComfortClient:https://www.futurehomesoftware.com/releases/ComfortClient-Setup-5.1.6.2.exeSounds for ComfortClient - Myma**:https://www.futurehomesoftware.com/releases/Comfort-Myma-Sounds-Setup-1.0.3.zipSounds for ComfortClient - Kate**:https://www.futurehomesoftware.com/releases/Comfort-Kate-Sounds-Setup-1.0.3.zipOpenXML Plugin for ComfortClient and Modbus Plugin:https://www.futurehomesoftware.com/releases/OpenXml.zipGaugePack 1 Add-on for ComfortClient:https://www.futurehomesoftware.com/releases/GaugePack1.zip Note: ** The contents of these packages (WAV Files) are copyright Cytech. I've packaged them in an installer that simply copies them in the correct folder location for the ComfortClient. You can also download these as seperate WAV files from the Cytech web site. Plugins: Modbus Plugin for ComfortClient: https://www.futurehomesoftware.com/releases/Modbus-Setup-4.1.3.1.exeWorld Weather Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/WorldWeather-Setup-2.1.3.1.exeData Monitor Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/DataMonitor-Setup-2.1.3.1.exeCurrent Cost Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/CurrentCost-Setup-1.0.3.1.exe Connectors: Application Connector for ComfortClient: Included in ComfortClient distributionEmail Connector for ComfortClient:Included in ComfortClient distributionGSM4 Connector for ComfortClient:Included in ComfortClient distributionMicrosoft SQL Server Connector for ComfortClient:https://www.futurehomesoftware.com/releases/MSSQLConnector-Setup-1.0.2.1.exeMySQL Connector for ComfortClient:https://www.futurehomesoftware.com/releases/MySQLConnector-Setup-1.0.2.1.exe Version History: ComfortClient:https://www.futurehomesoftware.com/releases/ComfortClient-Revision-History.pdf Modbus Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/ModbusPlugin-Revision-History.pdfWorld Weather Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/WorldWeatherPlugin-Revision-History.pdfData Monitor Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/DataMonitorPlugin-Revision-History.pdfCurrent Cost Plugin for ComfortClient:https://www.futurehomesoftware.com/releases/CurrentCostPlugin-Revision-History.pdf
 Current time is 05:45 pm
