| Posted: Tuesday Feb 17th, 2009 05:44 am |
| Posts: | 1636 |
| Status: |
New Version can be downloaded from here
This is a perfectly usable version, as long as the known bugs are taken note of
Bugs Fixed- Sensor Responses do not show References
- For Write to Comfort if a user code is entered instead of Engineer Code, a window "Incompatible File system" may be seen and the hourglass appears and remain on until the program is closed
- Error in HDL Configurator not able to change Assigned counters from 255
- Action If Zone, IF Last Zone parameters are wrong
- Sensor Responses are not Written to Comfort
- Action Get Counter 0 causes Error
- Creating new Responses from Events - may not select new responses if the IF statement is used
- Add a New Response adds the Response numbered 1 and causes other Responses after the new Response to be renumbered. Do Response points to the wrong Response
- UCM does not show in toolbar if selected in Options
- Response Wizard > Misc > Comment is not saved
- Response Name is not allowed to start with a Number, but if the name is autogenerated from the Description, the name starting with a number is accepted
Known Bugs (May be present in older beta versions)- When Adding a Response, a Response number is suggested by Comfigurator which points to an unused Response. However the drop down list will still be able to select lower numbered Responses which are used, and this will cause problems with DO RESPONSE actions in the new Response. DO NOT select lower numbered responses, always accept the Response number offered
- File Export > Responses. The first Response in the list cannot be selected
- For File System 31, the condition If Input is not able to select a Input/zone name
- Response Wizard - Action Keypad > Set Message tag for recording selects wrong parameters for Reminder and Alarm Message
- When Reading Event Log, if a reply is not received to E?00 or E? commands, the program hangs
- When deleting a Response, the focus goes to the top of the Response list instead of remaining where the deleted Response was
- SMS Phone Type can be selected even if UCM/GSM is not present in UCMs
- Do Response after Timer gives the wrong Response number if the tarhet response is > 254
- Action code sequence 79,255 causes Exception
- If Input condition cannot select SCS/RIO Inputs
- When FS34 file is converted to FS31, Response numbers > 127 are not flagged as Errors
- The following (illegal) action codes cause exceptions and prevent reading from Comfort where these actions may have been entered by keypad: 112 to 127 with no parameters, 128 to 195 with 0 or 1 parameters, 194 with 0 or 1 parameters, 195 with 0 or 1 parameters, 197 with 0 or 1 parameter eg 197,1, 198 with 0 or 1 parameters, 200 with 0 or 1 parameter
- Action 199 has a problem. If you use Response wizard, eg Announce 1 becomes 199,145,255 but when you Edit Action codes and enter with the same action 199, 145 it gives Invalid Codes.
- When ccl files are saved as cclx, the Do Response references are incorrect
- When a fixed Response eg N is referenced in a DO RESPONSE N action, and the Response N is changed to add more actions so that the number of actions exceeds 8 and a new Response Number M is allocated, then the Do Response action still points to the old Response number N
| Posted: Tuesday Feb 17th, 2009 05:24 pm |
| Posted: Wednesday Feb 18th, 2009 12:09 am |
| Posts: | 1636 |
| Status: |
The new actions will be added after the initial release, as we are keen to get the software release soon
Anyway the actions only worlk on firmware 5.166 which is also beta
| Posted: Thursday Feb 19th, 2009 08:15 am |
Developers
When deleting a response the focus is always reset to the top of the list (lots of scrolling to get back to where you were).
The code is intelligent enough to move the cursor/row highlight to the next response so why cant the focus be left on this item too; ie in the area where you just deleted?
J
| Posted: Thursday Feb 19th, 2009 01:39 pm |
| Posts: | 1636 |
| Status: |
Your wish shal be granted
| Posted: Thursday Feb 19th, 2009 01:45 pm |
Developers
Oh thats fab, I can stop polishing my magic lamp now then
| Posted: Thursday Feb 19th, 2009 03:28 pm |
wexfordman
| Posts: | 29 |
| Status: |
juwi_uk wrote: Oh thats fab, I can stop polishing my magic lamp now then
Cough!!
| Posted: Wednesday Feb 25th, 2009 08:31 am |
Developers
Is there a 2.9.15 beta or is V3 close to release now?
J
| Posted: Wednesday Feb 25th, 2009 10:31 am |
| Posts: | 912 |
| Status: |
The list of known bugs (see 1st Topic) is being fixed, and a new version wil be available after that, perhaps the first official release
| Posted: Thursday Feb 26th, 2009 08:09 pm |
Developers
A possible enhancement request for a future version.
When editing responses which have multiline components either in the "Response Wizard" or "Edit Response Manually" modes ie
If Flag Flag16 = 0 Then
Siren Chime
End If
Would it be possible hightlight the relevant part of the complete action code string depending on the line where the curosr is sat at edit stage
132,16,2, 115,2, 64,15, 255
ie if the cursor is on "Siren Chime" then the "64,15" would be hightlighted too in say blue in the complete string above if you get my meaning.
| Posted: Thursday Mar 5th, 2009 11:34 am |
 Current time is 06:36 am | |
