Posted: Monday Apr 18th, 2016 07:59 pm |
MDKKEN
Posts: | 38 |
I have the wired version of Fibaro Smoke Sensor FGSS-001 that is wired to comfort.
This device supports Multilevel Sensor V1. I thought "sensor" would be available in register type drop down. In mine I only have flag and counter.
I have latest firmware for ZWave and Comfort. Also latest version of configurator 3.11.1.0.
Am I mistaken? I use VERA Edge as the primary controller.
Posted: Tuesday Apr 19th, 2016 09:54 am |
yuanchang
Posts: | 6 |
Hi MDKKEN,
There are two solutions for this Fibaro Smoke Sensor FGSS-001's usage:
First solution is to include this device into Z-wave network and use the UCM/Zwave learn from the primary controller. After that, map the device with any counter in comfigurator. Under corresponding counter response, program alarm trigger if the counter change to a certain value.
Second solution is to connect the smoke sensor to any input of comfort directly and set the corresponding zone type as "Fire NC".
