Posted: Saturday Jan 16th, 2016 07:33 pm |
AdrianL
Posts: | 64 |
I wish to exclude a Virtual Node. The manual says [put the Primary Controller in Exclusion mode]
Select the Virtual Node in Zwave Configurator and press the Virtual Node
Info - SEND button seen in the right pane for the selected Virtual Node (Do
NOT press the Send Node Info button in the top menu).
When I select the Virtual Node there is no Info SEND button in the "Z-Wave Mapping Properties" panel on the right. I am using Comfigurator 3.10.11.0
Posted: Monday Jan 18th, 2016 09:57 am |
This appears to be a bug in Comfigurator 3.10.9 onwards
can you downgrade to 3.10.6 or 3.10.7 until the next version is released?
Sorry about the inconvenience
Posted: Tuesday Jan 19th, 2016 08:45 pm |
