Posted: Saturday Jan 3rd, 2015 11:13 pm |
Chaps,
I've been messing with the Fibraro universal module which has different inputs on board; 2 x inputs and a 1-wire temp bus.
http://www.amazon.co.uk/Fibaro-FGBS-001-Universal-Binary-Sensor/dp/B0093K2D1C
In the ZWave mappings for the UCM we can only set the register type for all registers assuming they are the same. Could this be changed in future so you can set per register.
I'd like to be able to map inputs to inputs/flags or counters and the temperature to a sensor. At the moment everything needs to be a counter (or flag, the latter of which is pretty useless for temp measurement !).
Attachment: screen2.png (Downloaded 80 times)
Posted: Sunday Jan 4th, 2015 07:31 am |
Posts: | 5495 |
according to your image, the channel 3 sensor can be mapped to a Comfort sensor?
Posted: Sunday Jan 4th, 2015 01:35 pm |
Posted: Tuesday Jan 6th, 2015 04:05 pm |
Posts: | 5495 |
can yiou send the cclx file to support@cytech.biz with the learned module?
we are curious to see the properties of the fibaro device
Posted: Wednesday Jan 7th, 2015 10:25 pm |
Posted: Saturday Jan 10th, 2015 01:10 pm |
Posts: | 5495 |
we just wanted to see the device in the list. But as you say you can only select one mapping, unless you create a virtual node
Posted: Saturday Jan 10th, 2015 01:25 pm |
OK but I'm now confused.
Why is it that the physical device only shows Counter or Flag but a virtual device shows lots more register types. Where is the limitation; device, firmware, comfigurator?
If I was to use a virtual node I have no idea how to map that to a particular sensor on the 1-wire bus connected to the Fibaro Universal.
The "universal "supports 2 x inputs and up to 4 x Dallas temp sensors.
Posted: Tuesday Jan 27th, 2015 10:39 pm |
Posts: | 560 |
I am going to jump on this bandwagon. I purchased a UCM/Z-Wave, a Remote, one Switch and a Fibaro Universal device.
Has any progress been made to map a Z-Wave temperature sensor to Comfort Sensor?
Posted: Wednesday Jan 28th, 2015 02:16 am |
Yep I'm "officially confused". :0)
If I can map a counter then why cant I map a sensor too; surely a comfigurator limitation as they both store a 16 bit value.
Ju
Posted: Wednesday Jan 28th, 2015 07:18 am |
Posts: | 5495 |
Zwave has evolved over time becoming more complicated
Originally there were no multi-channel nodes. Then they added multichannel nodes but each channel is supposed to be the same class, or that is what we thought
A multichannel device can only be mapped to one type of Comfort Register ie Counter, Flag or Sensor
The Fibaro universal sensor module has 2 channels of binary switches and optional channels which may be connected to various sensors, manual link http://www.fibaro.com/manuals/en/FGBS321-Universal-Sensor/FGBS321-Universal-Sensor-en-1.2.pdf
When the UCM/Zwave checks each node it will look for the classes supported by the channels in the device. if it supports multilevel sensor class then it allows mapping to a Comfort sensor. If it does not support tye multilevel sensor class, then it allows mapping to Counter or Flag. The Fibaro Universal device did not support the mulitlevel sensor class according to the UCM/Zwave query reply, that is why it was not mapped to sensor, but to Counter or Flag. This device does not seem to be a certified Z-Wave device, so perhaps it there is some problem with it. see http://products.z-wavealliance.org/
Zwave Multilevel sensor class is always mapped to sensors not flag or counter because our sensors are meant to be used for sensor data, so there is no confusion between the use of sensors and counters
A Virtual Node is created inside the UCM/Zwave to mimic a Zwave node. The virtual node is meant to allow zwave devices to associate to it so that commands or status can be sent to comfort. Hence it can be maped to Counters, Sensors, Flags, Response, Outputs etc
Some of the limitations of mapping are due to the original design of the UCM/Zwave firmware. When new features were introduced by Zwave like the multichannnel class, Virtual nodes and Bridge controller, we had to maintain backward compatibility with the older firmware implementations.
Posted: Wednesday Jan 28th, 2015 08:07 am |
Posts: | 560 |
Are there plans to update the discovery of this Binary Switch/Sensor so we can select either Counter or Sensor depending on the capabilities of the device? I fear more devices from Fibaro is going that route, just look at their RGBW controller, it has multiple analogue inputs, RGB controller etc. Even their Door/Window switch has a temperature sensor - of which I plan to buy a few soon.
Posted: Wednesday Jan 28th, 2015 08:19 am |
Posts: | 5495 |
Ingo wrote: Are there plans to update the discovery of this Binary Switch/Sensor so we can select either Counter or Sensor depending on the capabilities of the device? I fear more devices from Fibaro is going that route, just look at their RGBW controller, it has multiple analogue inputs, RGB controller etc. Even their Door/Window switch has a temperature sensor - of which I plan to buy a few soon.
UCM/Zwave does allow mapping of Counter or Sensor based on the command class supported by the device
It is only for Multichannel class devices where each channel supports a different class that this is not possible without a complete redesign of the UCM/Zwave firmware which is not likely to be in the near future
By the way the Universal sensor was found not to support the multilevel sensor class as mentioned in the above post. What value does it report then?
