Posted: Thursday Aug 7th, 2014 12:21 am |
Howser
I am using CBUS as my main lighting platform. When Cytech introduced the UCM/Zwave, I decided to go that route for all the non-wired lights (like side-lamps) and a door locks.
All works well, CBUS interacting with Comfort, and Comfort with Zwave.
I started playing with the idea of CBUS as a lighting platform interacting with Zwave as another lighting platform. Meaning having a group address attached to a counter which is attached to a Zwave light. Control being on both platforms, CBUS and Zwave, and Comfort being a middle man (with no control). I believe this was not the design intent. The intend was for either, and not both. It would be cool though, if this was done.
Posted: Thursday Aug 7th, 2014 06:28 am |
If you have a counter that is mapped to both Zwave and Cbus, then changing the value of the counter will send commands to both systems
Or if you have Zwave as a sender mapped to a counter which is also mapped to C-Bus then that will send a command from zwave to CBus
Is that what you have in mind?
Posted: Thursday Aug 7th, 2014 09:24 am |
Howser
If you have both Cbus and Zwave mapped to the same counter, when Cbus changes the counter, send a command to Zwave, and visa versa.
Posted: Thursday Aug 7th, 2014 10:00 am |
Howser wrote: If you have both Cbus and Zwave mapped to the same counter, when Cbus changes the counter, send a command to Zwave, and visa versa.
That is correct
Posted: Thursday Aug 7th, 2014 10:29 am |
Howser
I had tried the dual mapping, and from the Cbus logs saw that the GA was continuously switched ON and OFF from comfort in the early mornings between 0200 and 0500.
Not sure if this was indeed Comfort or Zwave.
Posted: Friday Aug 8th, 2014 04:18 pm |
Try disabling the Zwave from the counter and see if that still occurs
Posted: Friday Aug 8th, 2014 04:49 pm |
Posted: Friday Aug 8th, 2014 05:00 pm |
There must be some zwave commands getting sent to Comfort which triggers the cbus
Posted: Friday Aug 8th, 2014 06:34 pm |
Howser
Control from Zwave is via a physical on/off switch which is in a room that ir usually armed around the time that the issue occur. Nothing else controls that unit.
Posted: Sunday Aug 10th, 2014 06:57 am |
use the IO Monitor to capture the CT commands (Counter update)
This may give a clue on what is causing this
In the Counter, right click and select Check References to see what events are triggerng the counter
The counter can only be changed by Cbus, Zwave, other ucms which are mapped to the same counter, or a Response. It cannot turn on without any cmmand to it
Posted: Sunday Aug 10th, 2014 10:57 am |
The Object Matrix in my latest ComfortClient version may be of help here as you can monitor the situation over a period and then just output the history for the selected counters.
I have noticed a similar "counter flicker" with one of my ZWave responses when testing the Object Matrix. I have a door sensor and PIR that, at night, the light is meant to turn on when somebody enters from outside. The response works fine but I think it creates a lot of counter updates for some reason which I've yet to debug myself.
Anyway just a thought.
Posted: Monday Aug 11th, 2014 12:41 am |
Howser
There are no responses or any other references to this counter except Zwave.
Posted: Wednesday Aug 27th, 2014 09:21 am |
Hi Howser
Is this issue resolved? Does it happen again?
Posted: Friday Aug 29th, 2014 11:14 am |
Howser
I have been logging activity on Zwave side (with NO CBUS mapping) and I could not reproduce the issue.
I will re-map CBUS and see if that makes any difference.
Posted: Friday Sep 5th, 2014 07:54 am |
Howser
It is still occurring. When it does, the GA is turned ON and then OFF a couple of times (from CBUS it looks like Comfort is doing it). Most of the time, ON is immediately followed by OFF.
2014/09/05 03:16:07 AM Lighting Group= 100 Unit= 127 Event= Group on
2014/09/05 03:16:07 AM Lighting Group= 100 Unit= 127 Event= Group off
2014/09/05 03:16:22 AM Lighting Group= 100 Unit= 127 Event= Group on
2014/09/05 03:16:23 AM Lighting Group= 100 Unit= 127 Event= Group off |
Posted: Saturday Sep 6th, 2014 07:08 am |
To determine the cause of this, we need the Bus Monitor
This will show what causes the counters (or flags ) to switch on or off
Posted: Wednesday Sep 10th, 2014 12:44 pm |
17th Post |
Posted: Saturday Sep 13th, 2014 07:53 am |
18th Post |
The Bus monitor log shows the the UCM/Zwave (UCM ID 4) is triggering the Counters 100 and 253 from a multichannel device. The counters 100 is mapped to your cbus Family Room side lamp, while 253 is not mapped to any Cbus group
You wil have to investigate why the zwave channels are triggered from the Zwave device
Posted: Wednesday Sep 17th, 2014 11:10 am |
19th Post |
Posted: Wednesday Oct 1st, 2014 01:02 am |
20th Post |
Howser
I investigated the Zwave side and looking at the logs (attached), I can see the node being polled, but nothing purely switching the node ON and OFF.
08 09/30/14 22:47:41.504 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2d9db680>
08 09/30/14 22:47:41.504 JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d9db680>
08 09/30/14 22:47:41.504 JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.2.232 <0x2d9db680>
08 09/30/14 22:47:41.505 JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=34:e2:fd:1e:1e:da <0x2d9db680>
02 09/30/14 22:47:45.103 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:47:47.233 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:48:09.372 [33;1mZWaveSerial::GetFrame 0x2b7daef0 timed out now 0 m_listGetFramePending 0[0m <0x2b7db680>
02 09/30/14 22:48:09.372 [33;1mZWaveJobHandler::SendDataAbort got m_iFrameID 0[0m <0x2b7db680>
02 09/30/14 22:48:09.373 [33;1mZWJob_PollNode::ReturnMessageNotReceived -end- job job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:5 node 19 didn't reply iOK 25 iBadTx 0 iNoReply 25 Abort returned m_iFrameID 0[0m <0x2b7db680>
02 09/30/14 22:48:09.373 [33;1mZWJob_PollNode:ollFailed job job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:5 node 19 battery 0[0m <0x2b7db680>
06 09/30/14 22:48:09.373 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: [35;1mLastError[0m was: Poll failed now: Poll failed #hooks: 0 upnp: 0 v:0xa147a8/NONE duplicate:1 <0x2b7db680>
04 09/30/14 22:48:09.374 <Job ID="865" Name="pollnode #19 3 cmds" Device="44" Created="2014-09-30 22:47:45" Started="2014-09-30 22:47:45" Completed="2014-09-30 22:48:09" Duration="24.273150000" Runtime="24.272377000" Status="Failed" LastNote="" Node="19" NodeType="ZWaveMultiEmbedded" NodeDescription="Family Room Side Lamp"/> <0x2b7db680>
02 09/30/14 22:48:09.375 [33;1mJobHandler:urgeCompletedJobs purge job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:2 pollnode #19 3 cmds status 2[0m <0x2b7db680>
50 09/30/14 22:48:20.110 luup_log:17: Received: unknowncommand 14 <0x2d5db680>
02 09/30/14 22:48:55.104 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:48:57.243 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:48:59.402 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
04 09/30/14 22:48:59.552 <Job ID="866" Name="pollnode #19 3 cmds" Device="44" Created="2014-09-30 22:48:55" Started="2014-09-30 22:48:55" Completed="2014-09-30 22:48:59" Duration="4.451047000" Runtime="4.449414000" Status="Successful" LastNote="" Node="19" NodeType="ZWaveMultiEmbedded" NodeDescription="Family Room Side Lamp"/> <0x2b3db680>
50 09/30/14 22:49:20.110 luup_log:17: Received: unknowncommand 14 <0x2d5db680>
08 09/30/14 22:49:50.112 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: [36;1mLogIpRequest[0m <0x2d9db680>
08 09/30/14 22:49:50.112 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2d9db680>
08 09/30/14 22:49:50.112 JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d9db680>
08 09/30/14 22:49:50.113 JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.2.225 <0x2d9db680>
08 09/30/14 22:49:50.113 JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=38:0f:4a:9a:bd:57 <0x2d9db680>
50 09/30/14 22:50:20.110 luup_log:17: Received: unknowncommand 14 <0x2d5db680>
02 09/30/14 22:50:25.103 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:50:27.232 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
02 09/30/14 22:50:29.373 [33;1mZW_Send_Data node 19 NO ROUTE (nil)[0m <0x2b7db680>
04 09/30/14 22:50:29.502 <Job ID="867" Name="pollnode #19 3 cmds" Device="44" Created="2014-09-30 22:50:25" Started="2014-09-30 22:50:25" Completed="2014-09-30 22:50:29" Duration="4.401062000" Runtime="4.399755000" Status="Successful" LastNote="" Node="19" NodeType="ZWaveMultiEmbedded" NodeDescription="Family Room Side Lamp"/>
Attachment: Zwave Log.txt (Downloaded 4 times) Last edited on Wednesday Oct 1st, 2014 11:17 am by slychiu
Current time is 02:45 pm | Page: 1 2 |
