Function of RESET to Factory Default Button
 Posted: Thursday Aug 25th, 2011 12:25 pm
The button Reset (Reset to Factory Default) in the Zwave Configurator  resets the UCM/ZWAVE to Factory Default including the Z-wave properties and Counter assignments.
This does not remove the UCM/ZWAVE from the Z-wave network - that can only be done by the Primary controller.
AVOID THIS UNLESS THE UCM/ZWAVE IS NOT TO BE USED FOR THE CURRENT Z-WAVE NETWORK, OTHERWISE A NEW LEARN OPERATION WILL ADD A DUPLICATE NODE FOR THE UCM/ZWAVE NETWORK
Refer to the UCM/Zwave manual at http://www.cytech.biz/ucmzwave_manual.html
Attachment: ZwaveConfig.jpg (Downloaded 35 times)
 Current time is 10:23 pm
