Building RS232 commands
 Posted: Thursday Jun 4th, 2009 09:27 pm
I have a question on  the "Escape" character 15.
I assume this applies to ZWave ID's as with the dim value etc as both can take "15" or "255" as valid settings, right?
So if I need to command for say  ID 15 and 16 in a basic commannd (multicast then by type) ,  does the command string look like
197,{ucm#},1, {# of ID's}, 15. 15, 16 , {dim level}
But does the {# of ID's}  include or exclude the Escape Character(s); ie is it 2 or 3 in the above example?
 Posted: Friday Jun 5th, 2009 12:35 am
The number of ids should exclude the escape character
The string in action 197 is parsed by Comfort to remove the escape characters before they get sent to the UCM/Zwave
The need for escape is just to handle the 255 byte which is a terminator in action codes (a remnant of keypad programming)
 Posted: Friday Jun 5th, 2009 04:25 am
OK
So the {# of ID}'s  value itself doesn't include the extra escape characters.
But if the {#of ID's} is 15 itself then it's 15,15 before the first real ID value is listed in the string?
 Posted: Friday Jun 5th, 2009 08:17 am
that is correct (I think)
 Posted: Friday Jun 5th, 2009 09:26 am
Correct me if I am wrong but the ucm# is actually 16 + UCM#, I think.... UCM01 in the system will have an ID of 17, UCM02 will be 18 and so on...
 Posted: Friday Jun 5th, 2009 09:40 am
Yes you are right. The 1st UCM  is 17, so you dont have to worry about an ID of 15, as it does noty exist
 Current time is 06:44 am
