UCM/Zwave2
 Posted: Sunday Mar 29th, 2009 09:41 am
We are pleased to announce that UCM/Zwave 5.180 has now been released
This is a significant improvement over the previous version
  1. The new UCM/Zwave  works with the new  Comfigurator 3 software to learn a Zwave network and to assign counters for monitoring status
  2. The UCM/Zwave now comes with an EEPROM (Erasable Electrical Programmable memory) which stores the configuration settings, unlike the previous model which required the use of jumper settings to set the base counter
  3. The Z-wave configuration is stored in the .cclx comfigurator file together with the rest of the  configuration for the project.
  4. The Z-wave Node IDs in the network can be controlled using the Z-wave Comfigurator for testing (see screenshot below)
Cytech is offering a free upgrade to customers who have bought the older UCM/Zwave, as this requires a change in the UCM/Zwave PCB. Please send a private message or email sales@cytech.biz with the serial number of your current module
A screenshot of the Zwave Configurator built into Comfigurator 3 is shown below
The Z-wave configurator will be the model for new UCMs developed in future for interfacing to 3rd party equipment in future
The instruction manual can be downloaded from http://www.cytech.biz/ucmzwave_manual.html
Attachment: zwave screen.jpg (Downloaded 152 times)
 Posted: Wednesday Apr 1st, 2009 08:34 am
Minor Bug in UCM/Zwave 5.180
Status report updates Comfort Counters when there is no change in the value. Update of the counters should take place only when there is a change in the Zwave monitored value
 Posted: Monday May 4th, 2009 09:00 am
Hi Chiu
Is there any later (beta?) firmware for zwave to fix the counter issue yet or add some new features?
Keen to test.
 Posted: Tuesday May 5th, 2009 02:49 am
We are testing the new firmware, will let you know when it is ready
 Posted: Saturday May 9th, 2009 08:58 pm
Hope it's not too long in testing as I'm being saturated with zwave feedback on the RS485 bus as the moment so would be good to test the beta firmware if it fixes.
 Posted: Tuesday May 12th, 2009 12:32 pm
This is still going through testing. We wil let you know when we have anything foor you to test
 Posted: Sunday May 24th, 2009 02:07 am
The new firmware Zwave 5.184 has been released, downloadable from the  Zwave Firmware Page  on the Cytech server
This fixes a bug on 5.180 where the status report updates the counter  to Comfort even when there is no change in state of the Zwave device
 Posted: Sunday May 24th, 2009 05:03 pm
Have flashed my ZWave UCM with this and the counter problem has definately gone.
It's looking good.
 Posted: Wednesday Dec 16th, 2009 02:21 am
rolan
What is Max RF output power for UCM/Zwave module?
 Posted: Tuesday Feb 28th, 2012 10:19 pm
lwillerton
Hi All,
How do I upgrade to the latest z-wave firmware? I am running 5.218
Also I am trying to get feedback on the status of a home-pro application module (either on or off) I have set a counter and assigned to the ID, I have also set the counter under the control menu / control group feedback name and set to show status. This worked for my home-pro light modules.
Also why don't I see the counter value as per the pic shown by admin?
Cheers
Lee
Attachment: Capture.JPG (Downloaded 38 times)
 Posted: Thursday Mar 1st, 2012 12:06 am
The  new Zwave firmware firmware can be downloaded from http://www.cytech.biz/ucmzwave_firmware.html
The new Zwave 3 manual can be downloaded from http://www.cytech.biz/ucmzwave_manual.html
See http://www.comfortforums.com/forum62/2747.html
However older UCM/Zwavce may not support the Bridge Controller function which alows 2 way operations. A tutorial will be available shortrly
 Posted: Thursday Mar 1st, 2012 05:24 pm
lwillerton
UCM 1 6002
UCM 2 5.218
How do I upgrade the UCM 2? dont think I can do it by direct cable.
I purchase the Z-Wave UCM in the last 12 months so will this support the 2 way comms?
Cheers
Lee
 Posted: Friday Mar 2nd, 2012 01:34 am
13th Post
You can upgrade UCM version 5.xxx using UCM programming cable see http://www.comfortforums.com/forum4/1216.html
When you say UCM2 5.218, UCM2 refers to the UCM name. More important is the UCM Type eg ZWave, Cbus or General You can only upgrade a UCM to the same type ie Zwave to Zwave or Cbus to Cbus
 Current time is 11:07 am
