Posts: | 5498 |
Installers should ensure that they use the latest firmware on new installations, and NOT older firmware on systems which have been purchased some time ago.
This is important because older firmware may have problems which have been discovered and fixed and documented in the Firmware History topics in this forum
Installers who do not use the latest firmware are causing themselves (and us) needless problems
It is not necessary to upgrade systems which have been installed if none of the issues described in the "Known Bugs" list are encountered
Firmware Upgrade requires a UCM/232 (formerly UCM05), UCM/USB, or UCM/Ethernet. Instructions can be found at http://www.comfortforums.com/forum4/1216.html and also in detail on the UCM Manual on our website
