SCS part number changes and new manual
 Posted: Monday Feb 26th, 2007 03:52 am
Now that the SCS 6 button (Esprit) and 8 button models will be available, we have changed the part numbering system for these
SCS04 refers to the 4 button models
SCS08 refers to the 8 button models
SCS06 refers  to the 6 button model
These new SCS part numbers will come with a temp sensor
The SCS manual can be downloadsed from http://www.cytech.biz/temp/manuals/SCSman.pdf
The part number SCS01 will no longer be used
The part numbers for SCS switch panels are
SCS04-AL ( 4 button Aluminium)
SCS04-AN (4 button Anthracite)
SCS04-WH (4 button White)
SCS08-AL ( 8 button Aluminium)
SCS08-AN (8 button Anthracite)
SCS08-WH (8 button White)
SCS06-ES (6 button Esprit)
Only 4 button SCS have the IR option.
These are not standard, a longer lead time must be allowed
The frames available are (no change)
FR1-EV-AL (Event Alum)
FR1-EV-AN (Event Anthracite)
FR1-EV-WH (Event White)
FR1-STD-Wh (Std white)
FR1-E2-AL (E2 Alum)
FR1-E2-An (E2 Anthracite)
FR1-ES-GL (Esprit Glass)
Event is a convex frame
E2 and STD are regular square rounded edge frames
Esprit frame is glass
Any frame can fit into any SCS panel
 Posted: Wednesday Feb 28th, 2007 12:53 am
There is a small correction in the SCS  manual available from The SCS manual can be downloadsed from http://www.cytech.biz/temp/manuals/SCSman.pdf
 Current time is 08:04 am
