removing scs switches from comfort
 Posted: Tuesday Jun 20th, 2017 01:19 pm
wexfordman
I have 4 scs switches, but two of them are no longer used so I need to remove them from my configurataion. I go to modules and settings, delete the removed ones, and then do a selective upload to update modules and setting.
However, once I do this, and then do a scan for all modules, comfort still detects 4 scs switches, even though two are removed, so it should only detect the remaining two ?
Would appreciate some quick advice on this, heading away tomorrow, so just want to get the comms failure cleared.
Regards,Eamon
 Posted: Tuesday Jun 20th, 2017 02:15 pm
When you removed the SCS from the configuration did you also remove them from the system physically and change the ID setting so that the remianing ones are ID 1 and 2? If the SCS remain connected then Comfigurator will detect them and add them again
 Posted: Tuesday Jun 20th, 2017 02:20 pm
wexfordman
Hi, the scs are removed, but I didn't change the IDs of the remaining ones so that might be the problem
 Current time is 07:23 am
