getting scs led to blink
 Posted: Thursday Oct 13th, 2016 03:03 am
wexfordman
I want an scs output to display three different states for our immerion heater
1) Flashing:- Indicating immersion is on and heating water to a required temp.2) Hard on:- Indicating water has reached a specific temp.3) Off:- Indicating immesion is off, and water is not at temp.
Is a flahsing state possible for an scs led, the manual says no, but is there a logic I could aply to pulse the output ?
 Posted: Thursday Oct 13th, 2016 03:50 am
You can use Responses to Turn on the SCS output and off after a timer period to pulse the output, and do this periodically
 Posted: Thursday Oct 13th, 2016 05:38 am
Update - I have been told by R&D that the SCS output is able to Pulse and Flash. Please test in your SCS.
The Pulse Output command with Pulse duration does not work
However the Output command with Pulse and Flash parameter should work
 Current time is 03:32 pm
