Hi, as i can read from the user's manual, the SCS gives the output temp in °F but later, it says
"In the Home Control Menu, sensor registers may be used as a feedback. To
do so, the feedback type must be set to type 7 (which is sensor register)
and the feedback value set to the register number. (...)
The temperature may also be announced in either °F or °C. The default
setting is in °C."
In a response, the temperature is reported in °F (as indicated in the user's manual).
Can i have the temperature reported in °C in responses?
