SCS LEDS
 Posted: Sunday May 10th, 2009 08:59 am
engmoabel
Hi every one,
When i press on  any button of SCS after that the led of pressed button flashing ,
Is there any way to stop this flashing led ?
 Posted: Sunday May 10th, 2009 09:09 am
The led of the SCS wil start flashing when you press it until the led gets a command
You should send a command to control the led ie output on the SCS on or off
eg Output 129 ON or Off for SCS 1 LED
The led is for status, so when you press a SCS button you sending a command to the LED (output) is to give its status
 Posted: Sunday May 10th, 2009 09:23 am
engmoabel
how can i do this command ?
and send it
 Posted: Sunday May 10th, 2009 01:05 pm
Use the SCS/RIO Response eg
For SCS 1, Input/outputs 1 corresponds to Input/Output 129
Output 129 On or Output 129 Off to switch the led on or off
 Current time is 04:08 pm
