Failed Multiroom Audio Installation
 Posted: Monday Jun 25th, 2007 08:59 am
garym999
We were called in to fix several problems on a site where the previous installer did not manage to complete installation. One of the issues was that the audio system sounded C**P and distorted and was awkward to control
As installers we can all have our off days but what we found made us chuckle...
The system was based on active ceiling speakers but because the installer managed to find beams above there was not enough room to mount the active speakers. Careful positioning would have solved this. Anyway the design was changed to use separate speakers and amplifiers. Instead of using good quality 8ohm speakers cheap 100V PA speakers were used causing the sound quality issues.
In the attached picture you can see another wire coming out from under the speaker terminals. This is the IR remote control eye stuffed in behind the cone :D:D. No wonder the system was hard to operate.
Attachment: IMG_2704-1.JPG (Downloaded 111 times)
 Posted: Wednesday May 28th, 2008 08:09 pm
Muttley
Hey you must be really good :shock:
From what I can see you appear to have taken the photo when you were standing on the ceiling... let us in on the trick.. is it a pair of them DeWalt system integrator anti-grav boots or do you posses hithertoo undiscovered spidey type superpowers that we don't know about? :P
He he he...
Bubble burster strikes again!
Best Regards Matey
Gavin (Intelligent Buildings)
 Posted: Wednesday May 28th, 2008 11:20 pm
garym999
Yep thanks, there is no start to my talents!
 Current time is 01:22 am
