Pronto Conversion Utility
 Rating:  Rating
 Posted: Sunday Mar 30th, 2008 03:41 am
The Infrared Learning Tool current version 1.2.1.1 includes a Pronto Conversion utlity which is easy to use.
In Comfigurator, go to Tools > Infrared Utility
The IR learner opening screen appears. Click the New Tab to open a new dialog window as shown below
Enter the Product (brand), device and Model Number and click OK
Attachment: IR Leaner New.jpg (Downloaded 81 times)
 Posted: Sunday Mar 30th, 2008 03:50 am
The name of the new Remote control should be seen onn the top
In the Function box, click ADD
A new ADD NEW FUNCTION window appears as shown below
Enter the name of the function eg ON, OFF, Channel1, Bright, Play etc
Do not check the box old UCM01 (unless you have a UCM01)
The Serial Port is the connection to the UCM05, COM1 to COM16
This has to be entered separately from Comfigurator. Ethernet ports cannot be used for this
Check the box "Generate Signal via Pronto Hex Format. The screen below will appear
Attachment: IR Leaner Pronto.jpg (Downloaded 82 times)
 Posted: Sunday Mar 30th, 2008 04:00 am
The space at the bottom is to allow Pronto Hex codes to be entered
Pronto hex codes are the codes used to encode Infrared signals when they are learned. Pronto hex codes for many devices may be found in http://www.remotecentral.com. Warning - These are uploaded by users so not all of them may work
Open the hex codes in a text editor eg Notepad
Copy the hex codes for the function you wish to learn and PASTE it into the box
Attachment: IR Leaner Pronto hex.jpg (Downloaded 80 times)
 Posted: Sunday Mar 30th, 2008 04:05 am
Press Start. The Infrared signal which has been converted is displayed
Resolution - High, Medium, Low, Lowest affects how the signal is shown on the display
Tolerance is for encoding the IR signal nornally set to 15%
In Infrared Signal box,
Encode - will encode the signal to the IFR format
Crop is to remove parts of the signal which are mot needed
Save to file is to save the raw codes to send to us for analysis if the codes to not work
Attachment: IR Learner signal.jpg (Downloaded 80 times)
 Posted: Sunday Mar 30th, 2008 04:11 am
Press ENCODE. The screen below is shown. The codes are the reduced codes that are aaved in the IFR file for this function
Click YES to save the codes for the functgion in the IFR file
Repeat the process to convert  another function or button from the device
The codes for the device is now saved in the IFR folder in Comfigurator
You can select the device and functions to send the IR signal to any Comfort output
More functions for the device can be added or deleted at any time
If anyone has problems with converting any Pronto hex code or getting the converted codes to work, please send an email to support@cytech.biz and attach the Pronto hex file as well as the comverted IFR File
Attachment: IR Learner encoded1.jpg (Downloaded 80 times)
 Current time is 11:35 pm
