Daikin ARC452A3
 Rating:  Rating
 Posted: Saturday Apr 5th, 2014 02:27 am
cc_uk
I need to get IR codes for a Daikin ARC452A3.
I can try to 'learn' them via a UCM but when I click encode a large error box appears
Is there a guide to using the Infrared Utility?
 Posted: Saturday Apr 5th, 2014 07:40 am
The UCM Manual Section 5 explains how to do IR Learning
Download from http://www.cytech.biz/ucm_manual.html
Position the remote control 5 to 10 cm away from the UCM and not place too close
The BUSY1 LED should be on when it is ready to learn
When the IR signal is received the BUSY2 Red led will blink
You should see the IR signal displayed in the screen
 Posted: Monday Apr 7th, 2014 07:02 am
If you have any problem with the signal, press the "save to file" button, then send the file to support@cytech.biz
 Posted: Tuesday Apr 8th, 2014 01:21 am
cc_uk
Perfect thank you very much. that is working just fine for me now
 Current time is 05:19 pm
