web server module
 Posted: Monday Jun 5th, 2006 12:37 pm
rooster2001
i can change my ip adress but after press configure button its opening blank explorer page what can i do to solve this problem?
 Posted: Tuesday Jun 6th, 2006 12:23 am
adlim
Could you have changed the port as well? The "configure" button on CWM setup only supports port 80. If you have changed the port then you would have to manually key in the port as well.
 Posted: Thursday Jun 8th, 2006 01:43 pm
rooster2001
yes our port is already 80 but we are still unable to configure cwm . we can only change ip adress.
 Posted: Friday Jun 9th, 2006 02:16 am
adlim
That is indeed strange. What version is your CWM? If it is version 5.70, you try sending a reset to the CWM, as described in the CWM manual under the "Troubleshooting" section, and under "CWM Files have been Corrupted". Try triggering the response and see whether reverting to the default configuration helps.
 Posted: Tuesday Apr 24th, 2007 01:13 pm
BMagalhaes
I'm trying to bring CWM01 to Default Factory setings but something is still rong because nothing is hapening.
I'm using this string in the response:
Send RS232 2 52,45,53,45,54,50,57,44
CWM01 has ID=2
UCM/RS232 has ID=1
I would like to know to UCM ID should the string include, the CWM or the RS232?
Is the above response string correct?
Tks
 Posted: Wednesday Apr 25th, 2007 12:11 am
adlim
BMagalhaes wrote: I'm trying to bring CWM01 to Default Factory setings but something is still rong because nothing is hapening.
CWM01 has ID=2
UCM/RS232 has ID=1
Tks
You would have to send to the ID of the CWM not the RS232.
 Posted: Wednesday Apr 25th, 2007 12:16 am
adlim
Btw just noticed that you are only trying to reset the password and not to reset the CWM to the default configuration. Is that what you are trying to achieve? If not, you should be using this response:
    Send RS232 2 52,45,53,45,54,43,4F,4E,46
 Posted: Thursday Apr 26th, 2007 11:09 am
BMagalhaes
Right....Thanks for the help!
Another question, I'm trying to access CWM remotely to update the index file.
I'm connecting via FireFTP of Firefox web browser. When I log on to CWM it gets connected but the contents never appear.
I'm using a LinkSys Router to forward from the external IP to the Lan IP, I have the port 21 for FTP configured to the CWM Lan IP.
Should I configure any other ports to the CWM IP address?
What should I look for?
 Posted: Thursday Apr 26th, 2007 12:55 pm
adlim
Could it be a case of forgetting to enable the Engineer Sign-in Option?
 Posted: Thursday Apr 26th, 2007 01:50 pm
BMagalhaes
That shouldn't be the case because I'm doing it via Wizcomfrt and checking the Monitor.
This is what I see trough monitor when F + 0 + CODE + #
TO: KD0A
OK
TO: KD00
OK
PS01
AL1E000009025B
TO: KD06
OK
TO: KD07
OK
TO: KD08
OK
TO: KD09
OK
TO: KD0C
OK
LU12
TO: I?01
I?0100
TO: I?02
I?0200
TO: I?03
I?0300
TO: I?04
I?0400
TO: I?81
I?8101
TO: I?82
I?8200
TO: I?83
I?8300
TO: I?84
I?8400
TO: I?85
I?8500
TO: I?86
I?8600
TO: I?87
I?8700
TO: I?88
I?8800
TO: I?89
I?8900
TO: O?01
O?0100
TO: O?02
O?0200
TO: O?03
O?0300
TO: O?04
O?0400
TO: O?05
O?0500
TO: O?06
O?0600
TO: O?07
O?0700
TO: O?08
O?0800
TO: O?81
O?8100
TO: O?82
O?8200
TO: O?83
O?8300
TO: O?84
O?8400
TO: O?85
O?8500
TO: O?86
O?8600
TO: O?87
O?8700
TO: O?88
O?8800
TO: O?89
O?8900
TO: SR01
OK
TO: V?
V?FE0536222001
TO: U?
U?0A0546
TO: M?
M?0012
TO: UL02D201
DL02D201002B
TO: UL02DB01
DL02DB010022
TO: UL02E401
DL02E4010019
TO: UL02ED01
DL02ED010010
TO: UL02F601
DL02F6010007
TO: UL02FF01
DL02FF01FFFF
TO: SR01
OK
Looking at router side, what ports should I have forwarded to CWM?
 Posted: Friday Apr 27th, 2007 01:06 am
adlim
We just tried it out with FireFTP which appears to work well remotely and locally. Could it be some firewall or some settings on the remote router that is blocking the access?
 Posted: Friday Apr 27th, 2007 09:36 am
BMagalhaes
Please advise on what ports should be configured on the Forward Router table to the CWM IP address.
Tks
 Posted: Friday Apr 27th, 2007 03:56 pm
13th Post
adlim
You should have ports 20-21 opened, but I do not suppose its the router that is connected to the CWM that is causing the problem, but rather the settings on the router of the remote PC. Some routers do have a firewall which may block ftp.
 Posted: Friday Apr 27th, 2007 04:54 pm
14th Post
BMagalhaes
Found the problem... The FireFTP was configured as 'Passive Mode'. As I unchecked this option the content of CWM appeared...
Tks for the help!
 Posted: Monday Apr 30th, 2007 09:50 am
15th Post
BMagalhaes
Why does CWM opens several windows? Isn't it possible to have it opening in a single browser? The idea would be to have a main window where we could see the house and then selecting room (for example), CWM would change the picture on the browser!
 Posted: Tuesday May 1st, 2007 03:38 am
16th Post
I think it has to do with certain limitations of the process
Also if it has to upload the background image each time you want to go back to the image, it would be rather slow.
 Posted: Friday Mar 28th, 2008 02:04 pm
17th Post
cetinler
rooster2001 wrote: i can change my ip adress but after press configure button its opening blank explorer page what can i do to solve this problem?
I can connect to my control panel by using RS232 but i can not get an IP address from Web Server module with ethernet. On the CWM setup screen there will be not an IP. What could be the problem, why cant I see the Web Server Module?
 Posted: Saturday Mar 29th, 2008 01:28 am
18th Post
Can you disable any firewallsl you have in the network and try this again
 Current time is 03:31 am
