Comfort Automation/ Security System Forums > Products > Comfort Webserver Module (OBSOLETE) > Easiest way to display scs tem on web page (deg celcius)
 Posted: Wednesday Jun 15th, 2011 08:32 pm
wexfordman
I have managed to get readings from one of my scs's tem sensor to display in my cwm web page. Only very basic at the moment, but I am trying to figure out how to display it in deg celius (currently it is in farenheight). Here is what I have done so far
Comfort
Sensor 8 response activates a response "kitchen temp"
Kitehcen temp gets scs value and loads it into counter 27
CWM
I have greated a cntr with the following properties
cntr 27
divisor 1
display value quotient
values:- now this is where I need help
I think the above settings are correct, my difficulty is getting the readings from the scs to display in celcius, and to figure out a reasonalbe way to be able to display a temp range from -10 to 37 deg WITHOUT having create 47 different values and 47 different images of the numbers -10 to 38 ?
Appreciate any advice, and if I do have to source 48 different jpegs of the numbers -10 to +37, anyone have any decent ones I could use.
Thanks,
Eamon
 Posted: Wednesday Jun 15th, 2011 09:34 pm
wexfordman
Actually, I have figured out some of this, sorry. Saw the misc actions convert faren to celsius, so have at least got that far.
I have created jpeg files to represent the celsuis range -10 to 37, but while I know my counter is readying 21 deg, for some reason cwm is reporting back 2 deg !!
my cwm files are located here if anyone can help
http://www.4shared.com/folder/9C0c6IuT/_online.html
cntr2 is the one thats giving the problem.
Regards,
Eamon
 Posted: Friday Jun 17th, 2011 10:29 am
wexfordman
Still havnt figured this one out. Cant see for the life of me, why the coutner is reporting the correct value, yet my cwm is displaying a different figure altogether. Can anyone help ?
 Posted: Saturday Jun 18th, 2011 02:40 am
I cannot access that web page. It takes a long time trying to connect and comes up blank
 Posted: Saturday Jun 18th, 2011 09:40 am
wexfordman
Hi ident,
Sorry, will try again or maybe email the files to you
 Posted: Saturday Jun 18th, 2011 09:43 am
wexfordman
Or I could enable FTP access to cwm and you could access it via the details I gave earlier?
Edit:- Actually, while the above can be done (and i've enabled it on my router), it means using comfigurator first to do the keypad entry of f0 (comfigurator using port 10002) and then ftp. Its prob a bit too cumbersome to do it that way, so I will email the files to you next time I am home instead.
Eamon
 Posted: Sunday Jun 19th, 2011 10:19 am
wexfordman
Hi ident, I have emailed all the files to support,
Eamon
 Posted: Sunday Jun 19th, 2011 10:01 pm
wexfordman
Stop the Press, I think I have it sorted :-)
The final problem I think was the way I had the cntr display propoerties in cwm. I had it set to display remainder, instead of quotient, and the divisor was 10 instead of 100.
For info, I will post up how I actually configured an scs temp reading to display on cwm in a new thread, might be usefull to others.
 Posted: Tuesday Jun 28th, 2011 09:16 am
wexfordman
As mentioned, I posted up how I did this, so if anyone is interested, you can find it here http://www.comfortforums.com/forum83/2324.html
regards,
Eamon
 Current time is 07:50 am
