Changed Pass though port / server error
 Posted: Tuesday Feb 10th, 2009 09:45 pm
  PMQuoteReply
marinoss
I have changed the default pass through port 10001 to another number saved the changes and after the server was rebooted I get
Server error: 404 not found.
The CWM module setup discovers the server and when I select [Configure] I get the Comfort Web Module Administration screen. After I select [Module Setup] and login, I get the above error. The same thing happens with all other options in the CWM Admin screen.
I tried to reset by pressing F0 and then executing the response 197,18,82,69,83,69,84, 67,79,78,70,255 (my CWM ID=2) but nothing happens. It seems the server is not restored to factory defaults since the CWM module setup discovers it at my custom IP address and not the default one.
Any ideas?
Back To Top
 Posted: Tuesday Feb 10th, 2009 11:50 pm
  PMQuoteReply
leonchue
You have to complete the process by doing a power reset on the CWM, after executing the response (ie power off for seconds and on again).  Have you done that as well?
Back To Top
 Posted: Wednesday Feb 11th, 2009 05:04 am
  PMQuoteReply
marinoss
I have done that as well. Actually I tried both the RESET button and the power off. No result.
Back To Top
 Posted: Wednesday Feb 11th, 2009 07:13 am
  PMQuoteReply
leonchue
I read your previous post again.  It seems that you have 2 problems.
The first problem is accessing the administration functions and the second one is unable to reset back to factory default.  Changing the pass through port should not result in these 2 problems.
Can CWM operate as a web server?  Like loading the web page (e.g. https://10.0.0.16/sampleindex.htm )?  Are you able to ftp into CWM?
Since you manage to reset to factory default previously, it should not be any problem this time round.  Make sure that the 485 LEDs are blinking correctly on CWM, the CWM ID is set to 2 and there is not another UCM ID 2 in the Comfort system.
What are the CWM, UCM and Comfort firmware version?  You may send them to me via private message.
Back To Top
 Posted: Thursday Feb 12th, 2009 05:17 am
  PMQuoteReply
marinoss
Hi I have sent you a PM on this subject.
Back To Top
 Posted: Monday Feb 16th, 2009 01:23 am
  PMQuoteReply
The problem was caused by changing the passthrough port to 80
Port 80 is reserved for http and cannot be assigned to the pass through port.
The CWM manual will be amended to include this specific instruction
Back To Top
 Current time is 06:35 am
