Posted: Monday Apr 21st, 2008 09:11 am |
pimpim32
Posts: | 8 |
I just got a CP9000 with a web server module to play with.
Even if it was bought brand new, the server did not have the 10.0.0.16 IP but something else. I succeded to reset to factory defaults, but I cannot acces the settings through web as admin user and password do not work.
All the other features, so far , are working properly(java applet, connecting with the Comfigurator etc)
However when I try to connect to the admin page I type "admin" and "admin", but no results, the password dialog keep poping up and no login.
What else I should do to be able to login?
Thank you.
Posted: Tuesday Apr 22nd, 2008 01:12 am |
Posts: | 1200 |
You need to enter F0 on the keypad to enable the Engineer code in order ato access the Admin pages
Posted: Tuesday Apr 22nd, 2008 07:58 am |
pimpim32
Posts: | 8 |
Engineer code is enabled.
And if it were not enabled according with manual still should let me to login and after that to tell me I need to enable engineer code.
Thank you
Posted: Tuesday Apr 22nd, 2008 02:28 pm |
Posts: | 1200 |
What is the version of the firmware on the CWM and the Comfort. There should be a label on the U1 ICs
Can you send the screenshot of the error message when you try to log in?
Posted: Tuesday Apr 22nd, 2008 03:45 pm |
pimpim32
Posts: | 8 |
Thanks for reply.
I will be away for 3 days, I will post what you asked then.
Posted: Thursday Apr 24th, 2008 12:40 am |
hendy
Posts: | 221 |
pimpim32 wrote: I succeded to reset to factory defaults, but I cannot acces the settings through web as admin user and password do not work.
Try to reset the password back to default i.e. "admin"; the instruction can be found on CWM manual page 61. It might be that somehow the default password has been changed. Password reset and factory-default reset are two different things.
Posted: Tuesday Apr 29th, 2008 11:44 am |
pimpim32
Posts: | 8 |
Thanks hendy
This was the correct answer. Password reset is different than CWM reset.
Now I got it allright.
Thanks again
