Hi Slychiu,
Thanks for your reply, I tried the Test Dial Out and it dials all the numbers in the security/phonen numbers, but stil:
1. I tried the SMS command (411) & (4011) individually to turn on the lights but both won't work. What is the correct command? I have attached the configuration in the control keypad.
2. How i can trace that it can recieve the SMS command? (in the comfigurator)
3. Why i cannot recieve also the reply sms message from comfort.
And aslo i try to call the sim inserted in the GSM Module from the landline and mobile it accept the call and i can control the lights. But using SMS command it did not work.
Thanks, hope you could give us time to figure this out.
Anthony Rodes
E-home Automation
Attachment: GSM_Comfort.jpg (Downloaded 176 times)
