Comfort Automation/ Security System Forums > Products > GSM Module > Comfort GSM not answering but SMS is working
 Posted: Sunday Jan 19th, 2025 11:54 am
caravanboy
I upgraded my system last week and replaced my old GSM(3G) UCM with the new UCM/A7608 which supports 4G and VoLTE. My main reason for doing this was because it was virtually impossible to sign-in remotely on the old 3G module.  Advice on the forums was that the new A7608 module decoded DTMF on-board and so performed better...
After initial installation I was able to sign-in on my second attempt - I assumed I fumbled the keys on the first one.  However, trying to dial-in this morning I've had five failed attempts.  My one-and-only successful sign-in so far must have been a fluke :(
I saw another forum post that recommended holding each key for 1 second then waiting for 1 second but that didn't seem to help (and if I do it that slowly after the first failed attempt Comfort sometimes seems to hang-up and say "Thankyou Goodbye" halfway through the second sign-in attempt anyway).  I used to use this slow method 10+ years ago when signing in to a Comfort landline and it did matter and make a difference.
I'm trying to dial-in from a Samsung S23 Ultra mobile. I have a good signal and Comfort has a "Strong" signal.  I'm not convinced my SIM is using 4G yet (the A7608 board's red LED is only flashing slowly) but my provider claims 3G has already been switched off in my area and assures me that my SIM is 4G compatible and I should be getting a 4G connection. Perhaps I'm falling back to 2G?  Would that matter and make DTMF worse for Comfort?
As you cannot hear the DTMF tones locally on the mobile I'm not sure if holding the key makes any difference anyway.  Actually, I just did a test and dialled a landline and pressed keys on the mobile so that I could hear them on the landline - it seems the mobile-generated DTMF tones are a fixed duration (I'd estimate ~250ms) so the only thing that can matter is the gap between presses.
Are there any other settings I can try on Comfort to tune things as this is really disappointing that I still cannot sign-in via GSM?
Also, I'm going to take the SIM out and check VoLTE is enabled etc (as recommended on other forum posts) - do I have to power down Comfort first, or is it safe to remove the SIM?
(apologies for the long post)
 Posted: Sunday Jan 19th, 2025 12:08 pm
caravanboy
BTW, I've tried searching for settings on the phone - I even found this one where someone claims you can change the phone to generate longer DTMF tones, but that setting does not exist on my UK Samsung - maybe it is country specific? :(
https://www.verizon.com/support/knowledge-base-306064/
 Posted: Monday Jan 20th, 2025 12:49 am
I believe you SIM card has VoLTE because otherwise you could not get the call connected and Comfort would not answer. It looks like either your mobile phone or the mobile network is causing this problem if you could not detect DTMF using the old 3G gsm module.
Can you try with another mobile phone?
 Posted: Sunday Mar 30th, 2025 09:00 pm
caravanboy
I have a relatively new 4G 7608A UCM module.  It was working when installed a couple of months ago* but I noticed a few days ago that if I dial the GSM number it just rings for ever and Comfort doesn't answer.
The SIM is okay and it must be registered with the network as it is still sending and receiving SMS texts okay.
So, two questions:
1. I'm hoping that a reset of Comfort will make it all work again but is there any other way to reset the UCM it without doing a full Comfort reset?
2. Before I do any resets are there any tests/diagnostics I can do to try and determine why this has happened as I only discovered this by accident and don't want to find it is stuck in this state in the future when I need to dial in during an alarm.
 Posted: Monday Mar 31st, 2025 01:48 am
Forts please chevck that the 5 way multicolour audio cable is connected between the GSM submodule and Comfort. This cable carries the voice signals and voice calls would not work without it
If it still does not answer calls, start  Comfort Bus monitor in Tools, then make a call to the GSNM. Save the Bus monitor IO is a file and let me know the contents by pasting here
 Posted: Tuesday Apr 8th, 2025 10:28 am
caravanboy
I checked the cable and it appears to be seated fine. It worked well when first installed and the installation hasn't been touched since so there was no reason to think the cable should be an issue anyway.
I tried a call with Comfort open and I noticed that on the UCM/GSM board D3 did a slow red flash and when the call came in D3 went solid red until I gave up ringing.
This morning I started the bus monitor, waited a couple of seconds then dialled in to Comfort GSM and let it ring for about 10 rings or more.
Here is the dump:
11: 12: 53: 731 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 03: 354 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 13: 09: 868 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 15: 234 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 13: 16: 297 ----< 03 40 41 30 30 30 31 30 30 30 30 37 42 02 <--->@A000100007B
11: 13: 17: 509 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 19: 704 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 13: 21: 792 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 28: 490 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 13: 30: 623 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 37: 278 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 13: 39: 471 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 13: 44: 037 ----< 03 12 7C 30 32 36 44 02 <--->|026D
11: 13: 46: 046 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
I spotted the "GSM cal ended" message at 11:13:44 but I didn't see one to say it started?
I tried it again just to be sure - started Bus Monitor then waited until it had displayed a few lines before dialling the GSM module at ~11:19:45. This is the output (I assume the initial "data crashed or ID collided" message is just a quirk and nothing to worry about)
***** 03 12 20 43 42 (had to erase non-printable chars as the forum kept saying "error")
11: 19: 32: 826 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 19: 36: 053 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 19: 42: 577 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 19: 48: 670 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 19: 50: 938 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 19: 52: 556 ----< 03 40 41 30 30 30 31 30 30 30 30 37 42 02 <--->@A000100007B
11: 19: 53: 262 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 20: 01: 996 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 20: 10: 728 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 20: 13: 847 ----< 03 12 7C 30 32 36 44 02 <--->|026D
11: 20: 15: 047 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 20: 19: 516 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 20: 21: 783 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
In case it is of any use to you, here is a trace from when I send a "(?)" message via GSM and receive a reply (I've blanked out a few digits as that looks like it would give away my mobile number ;))
11: 23: 23: 135 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
11: 23: 26: 399 ----< 03 21 3F 31 36 36 33 32 34 02 <--->!?166324
11: 23: 29: 256 ----< 03 12 7C 30 37 30 41 33 34 33 34 33 37 33 38 33 35 33 30 33 39 33 3* 33 3* 33 3* 33 3* 33 3* 45 32 02 <--->|070A343437383530393*3*3*3*3*E2
11: 23: 29: 304 ----< 03 12 7C 38 35 30 41 30 37 44 39 02 <--->|850A07D9
11: 23: 31: 327 ----< 03 12 7C 30 36 30 31 36 38 02 <--->|060168
11: 23: 36: 241 ----< 03 21 3F 31 36 36 34 32 33 02 <--->!?166423
Look forward to hearing from you.  I've still not reset Comfort yet in case there is anything else we can discover before I reset.
Edited as all the CRs had got lost!
 Posted: Tuesday Apr 8th, 2025 12:25 pm
It looks like the GSM has answered but the voice is not going through When the red Busy LED is on it means the gsm is  in operating mode.  It could be the cable is faulty.
when the gsm answers, can you press the user code and #key and eg 1 and 2 to arm to night mode. Does it try to arm to night?
 Posted: Tuesday Apr 8th, 2025 09:04 pm
caravanboy
Comfort doesn't answer though as far as the mobile is concerned - I still hear the ringing tone.
Should I just reset Comfort and see if it all starts working again?
 Posted: Wednesday Apr 9th, 2025 01:35 am
Please power off and on the gsm module to let it reconnect.
 Posted: Wednesday Apr 9th, 2025 01:44 am
Can you check if your sim card supports VoLTE?
what is your UCM GSM Firmware version (from Modules tab)
 Posted: Wednesday Apr 9th, 2025 01:47 am
The forum does not handle CRs. Please add a space before CR to allow the new linbe to display
 Posted: Wednesday Apr 9th, 2025 10:01 am
caravanboy
slychiu wrote: Please power off and on the gsm module to let it reconnect.
  Is there a specific way that I should do this - do you mean just pull the connector providing power and data?
slychiu wrote:Can you check if your sim card supports VoLTE? what is your UCM GSM Firmware version (from Modules tab)[highlight= rgb(255, 255, 255);]
 My UCM GSM firmware is 7.245
 I was told the SIM card supports VoLTE but I've not independently verified that.
 Posted: Wednesday Apr 9th, 2025 10:05 am
13th Post
Yes pull out the 4 way cable
 Posted: Wednesday Apr 9th, 2025 10:06 am
14th Post
 Posted: Saturday Apr 12th, 2025 10:58 am
15th Post
caravanboy
I pulled out the cable to the UCM GSM and replaced it. The module then behaved correctly and did answer my calls.
Still sounds like a bug though if it was able to send and receive SMS messages but had stopped receiving phone calls?
I also noticed that after re-inserting the cable the red D£ LED was flashing rapidly until it answered my call (then it went solid) but after the call ended it went back to flashing slowly. Any reason for the difference?
I still could not sign-in even with the newer 7608A module that I bought, but that is a separate issue. I need to do some more investigation and reply on my other topic about that.
 Posted: Saturday Apr 12th, 2025 11:08 am
16th Post
caravanboy
Unfortunately all the phones in our house are Samsung (varying ages from 2023 to very old models). None of them have the Android settings to set long DTMF tones.
Comfort does recognise some of the DTMF tones (with both old and new modules) as pressing * is recognised to interrupt the voice message but the sign-in digits are rarely recognised. Since getting the new module in January I have managed to sign in only once which is very disappointing as this was the whole purpose of buying the new phone?
I have downloaded Google 'Phone' app to try instead of the default Samsung 'Phone' but it seems that DTMF doesn't even work at all on their app!
Does anyone have a suggestion of a reliable way to get Comfort to recognise DTMF from Samsung mobiles? It is not as though they are an obscure brand!
 Posted: Sunday Apr 13th, 2025 01:32 am
17th Post
I personally have a Samsung (A54) and do not have any problem with recognising DTMF tones. The A7608 module is responsible for detecting DTMF tones, and not Comfort.
I can dial to your GSM Module from my phone in Singapore and check if I have the same problem. If you can temporarily add a user code eg 1234, and send your number to support@cytech.biz, I can let you know the result
 Posted: Sunday Apr 13th, 2025 03:46 am
18th Post
Have you seen this advice from Samsung for Long DTMF tones?
https://www.verizon.com/support/knowledge-base-304273/
 Posted: Sunday Apr 13th, 2025 10:40 am
19th Post
caravanboy
Yes, I have seen posts about short and long DTMF settings but I have a Samsung S23 Ultra with the latest software update (March 2025) and on the Phone "Other Call settings" there are no DTMF length options :-(
I have emailed you the GSM phone number and temporary user code.
 Posted: Monday Apr 14th, 2025 01:03 am
20th Post
sorry can you resend the email. I saw it last night but was unable to find it today
 Current time is 06:26 pmPage:    1  2  Next Page Last Page
