Posted: Tuesday Jan 9th, 2024 04:45 pm |
Ian
Posts: | 249 |
I had a look at Laser systems web and it the module appears to be 3G Will it work with 4G?
Comfort GSM Module version 4 (3G)
Posted: Wednesday Jan 10th, 2024 12:27 am |
Posts: | 5845 |
Laser should have UCM/4G. I believe they may not have updated their product list. I suggest that you check with them
Posted: Wednesday Jan 10th, 2024 09:09 am |
Ian
Posts: | 249 |
slychiu wrote: Laser should have UCM/4G. I believe they may not have updated their product list. I suggest that you check with them
Thank you.
Posted: Thursday Jan 11th, 2024 02:42 pm |
mikegriff
Posts: | 113 |
Is it possible just to buy the piggy back board which holds the sim?
Mike
Posted: Friday Jan 12th, 2024 12:23 am |
Posts: | 5845 |
Yes there is a part number GSM/4G. But the ucm/gsm base board should have firmware version 7. You will need to upgrade to the laest firmware which will work for 3G and 4G
Posted: Thursday Dec 12th, 2024 02:25 pm |
mikegriff
Posts: | 113 |
After the storms this week in the UK we lost power for 48hrs
my UCM/4G is reporting:-
GSM Network Strength 0 - no network
if i put the sim card in my phone then it seems to send a txt
What else could I try?
Posted: Friday Dec 13th, 2024 12:00 am |
Posts: | 5845 |
Try a complete power down. Check that the sim card is properly inserted and makes contact and is not loose in the card holder.
Do you have 2 antennas, and did you connect the 2nd antenna?
Is this a new gsm module?
Posted: Friday Dec 13th, 2024 11:14 am |
mikegriff
Posts: | 113 |
No difference
SIM Solid , and I have tried with the sim from my phone as well
Both have always been cionnected connected
If i try to phone in iget a message saying unavailable
Attachment: Configurator.JPG (Downloaded 24 times)
Posted: Friday Dec 13th, 2024 11:15 am |
Posted: Friday Dec 13th, 2024 01:57 pm |
Posted: Friday Dec 13th, 2024 06:50 pm |
mikegriff
Posts: | 113 |
I have moved the GSM module up to id 2, it didn't change any thing! I upgraded the GSM and the Maincontroller after the power outage, they were the only things I hadn't upgraded before the power out.so i have never had the GSM working under Version 7.245, also the software number i upgraded from was 7.000 which doesnt make any sence because I know I upgraded the firmare when i fitted the new board so it would have been 7.164 Also I'm sure that UCM/GSM Properties, GSM Module Type didn't say Not Supported by Firmware hope this helps a bit The sim card woorks in my phone, which i think means the transmitter is working for mobiles See Photo for latest UCM-GSM Mike Attachment: latest config.JPG (Downloaded 24 times) Last edited on Saturday Dec 14th, 2024 12:08 am by
Posted: Saturday Dec 14th, 2024 12:23 am |
Posts: | 5845 |
I think there is a mismatch between the ARM firmware and the gsm module SIM7600s baud rate since you say you never had this module working. I will send a different firmware for you to upgrade to
Posted: Saturday Dec 14th, 2024 09:12 am |
mikegriff
Posts: | 113 |
Thanks for this, I look forward to trying the new firmware. :-)Just for clarity I have had this unit working but not since the power outage of 48hrs and a firmeware upgrade to 7.245.Mike
Posted: Sunday Dec 15th, 2024 01:09 am |
Posts: | 5845 |
Can you check if the red and green leds on the gsm submodule (not on the baseboard) are on or blinking. If none of the leds are on, the Submodule may be dead
Posted: Sunday Dec 15th, 2024 08:01 am |
mikegriff
Posts: | 113 |
The red one between the aerial is Off then solid on , then flashes red . This repeats every minute
The green power is hard on.
It looks like a normal one of your working UCM’s :-)
Mike
Posted: Sunday Dec 15th, 2024 08:11 am |
Posts: | 5845 |
It look like a baud rate mismatch. will try new firmware
Posted: Sunday Dec 15th, 2024 06:29 pm |
17th Post |
Posted: Thursday Dec 26th, 2024 03:32 am |
18th Post |
Posts: | 5845 |
Mike, can you upgrade to this firmware GSMA8.004. If your prolem i caused by baud rate mismatch then this should fix it
Attachment: GSMA8_004.zip (Downloaded 1 time)
Posted: Wednesday Jan 1st, 2025 10:45 pm |
19th Post |
mikegriff
Posts: | 113 |
Thank You once again Chiu!!!Yet again you have come to my rescue :-)New firmware worked a treat
Comfigurator now reports:-GSM Network Strength 4 - strong Just like your service!!!!Mike
Posted: Wednesday Jan 1st, 2025 11:55 pm |
20th Post |
Posts: | 5845 |
Thats good. That means my guess that the baud rate between the UCM base and the GSM submodule was mismatched. Check if you have any problem with the time update from gsm giving the wrong results many tomes a day.
Current time is 06:03 pm | Page: 1 2 |
