GSM module poor reception
 Posted: Saturday Feb 17th, 2018 11:34 am
phil1155
Hello ,I just installed a GSM4 module. I am struggling finding a good position for the antenna and get a better reception. The log indicates a lot of trouble/restore messages.The best I have so far is a signal strength 2.
1- Is there a way to lock the module on 2G?
2- My antenna is very closed to the roof. So adding the adm02 modules should not help me I guess. Would it be possible to expand the antenna cable and put it outside on the roof? Or would an external and amplified antenna would be a solution?Ant recommended product?Thank you for your
help
Philippe
 Posted: Saturday Feb 17th, 2018 12:46 pm
1- Is there a way to lock the module on 2G? No it will lock onto the network of the sim card. If 3G is weak it should fallback to 2G
ADM02 can still help by allowing the UCM/GSM4 module to be located in a better position
There are some who have just extended the antenna cable by cutting and joining the cablee, buy I am not sure how well that would work in general
We have another antenna which is a higher gain type see attached image
in our testing it has increased the level by 1.
Attachment: JCG24.jpg (Downloaded 30 times)
 Posted: Saturday Feb 17th, 2018 03:27 pm
phil1155
Thanks Chiu, I will find one antenna and try. I wonder I should maybe buy a repeater (I have also the reception problem with my cell phones). But there are bloody expensive.
 Posted: Monday Feb 19th, 2018 06:22 pm
phil1155
Chiu, what type of antenna connector is on the gsm4 module ( mmcx, mcx ??)
 Posted: Monday Feb 19th, 2018 06:29 pm
Mmcx
 Posted: Thursday Feb 22nd, 2018 06:08 pm
phil1155
Just placed a better antenna. Got now a "Strength 3". Works fine now. Thanks Chiu
 Posted: Friday Feb 23rd, 2018 06:22 am
Great. Where did you get the antenna in case others need?
 Posted: Friday Feb 23rd, 2018 12:26 pm
phil1155
http://www.mhzshop.com/shop/index.php?cl=details&anid=d484e08979ab10c19.50627593
This is the model I selected. Not a single trouble/restore in the last 12 hours.Works perfect now (voice and sms).Cheers
 Posted: Saturday Feb 24th, 2018 06:04 am
That is an interesting device. Did you have to change the connector to MMCX or doe it come with? It does not state that it has MMCX
 Posted: Thursday Mar 1st, 2018 06:56 pm
phil1155
Sorry, I missed that.I had to buy a pigtail coming with a mcmx connector ( as the antenna comes with a different connector).Still working great with  Strength 3.
 Current time is 03:00 pm
