Posted: Monday Sep 30th, 2013 07:11 am |
In your upgrade steps for switching from 7.029 (GSM) to 7.030 (GSM4) can you be a bit clearer about when you physically replace the daughtercard in the sequence; is it while you are still on 7.029 or do you do once you have flashed to 7.030. Maybe it doesn't matter but good to be clear so you don't wreck anything.
Posted: Monday Sep 30th, 2013 07:27 am |
Posts: | 5497 |
You must replace the SIM900 submodule before upgrading to GSM4 firmware
If you do not have SIM900, ULT 7.037 (beta) will still have many of the new features except for the help functions
Posted: Thursday Oct 3rd, 2013 12:36 pm |
mikegriff
Posts: | 103 |
Hi Chiu
What would be my GSM upgrade path
my GSM seems to have a ribbon cable and no EEprom?
Thanks in advance
MikeAttachment: webgsm.jpg (Downloaded 154 times)
Posted: Thursday Oct 3rd, 2013 12:45 pm |
Posts: | 5497 |
You would need to buy a GSM4 submodule to replace the (Siemens) submodule that you have. I dont know if we have a price for that yet but it should not too high
Next you need to put in the U2 EEPROM. Yours does not have an IC socket in the U2 position. If you are handy with a soldering iron you can solder in the 8 pin IC socket and get a U2 eeprom to plug in
Posted: Thursday Oct 3rd, 2013 03:09 pm |
I presume all new UCM's are getting a U2 socket fitted as standard these days?
Posted: Thursday Oct 3rd, 2013 09:11 pm |
Posted: Thursday Oct 3rd, 2013 11:45 pm |
Posts: | 5497 |
U2 have been soldered in to all UCMs for many years, at least 3
Posted: Sunday Oct 20th, 2013 04:14 am |
UCM/GSM4 firmware 7.030 has been released
Please refer to upgrading method from UCM/GSM3 to UCM/GSM4 in the 1st post on this topic
Posted: Monday Oct 21st, 2013 01:53 pm |
mikegriff
Posts: | 103 |
Thanks Chiu
New module arrived and Eeprom installed
It is worth pointing out that you need to make a link where the jumper was that selected U2 as master.
I failed to spot this first time
Also I had only enabled
Allow SMS Conrol,Arm,Disarm
in the entry for SMS Not the entry for voice
This meant that any txt from my phone returned:
Command not permitted
This was cured by enabling the Voice phone
Hope this helps
Mike
Posted: Tuesday Oct 22nd, 2013 01:32 am |
hendy
Posts: | 221 |
Do you have 2 types of phone (i.e. Voice and SMS) with the same number programmed?
Posted: Tuesday Oct 22nd, 2013 10:14 am |
Posted: Tuesday Oct 22nd, 2013 08:54 pm |
We should have pointed out in the docs that both the Voice Phone and SMS phone which are programmed in the Phone numbers are allowed to send SMS to Comfort
So if you have both sms and voice phone with the same phone number, both numbers need to have the phone permits set up
Otherwise the firmware will find the 1st phone number that matches and use the phone permits for that phone
Thanks for the feedback, you are probably the first customer to upgrade and use UCM/GSM4.
Posted: Wednesday Oct 23rd, 2013 03:22 pm |
mikegriff
Posts: | 103 |
I think it is a great upgrade.
It proves that the daughter boards are a great idea as it is a reasonably priced upgrade for all.
Still playing with it
But it now is User friendly
Congrats all round
Mike
Posted: Wednesday Oct 23rd, 2013 04:01 pm |
Howser
In Comfigurator (using 3.7.6.0), where in the Response Wizard would I find Action 155 (Send SMS Message)? I am able to manually edit the action codes, but was wondering if was added to the Edit/Append new Action sub menus.
Posted: Wednesday Oct 23rd, 2013 06:40 pm |
Send SMS Message should be in the Output Menu which may not be the most logical place to find it
Posted: Wednesday Oct 23rd, 2013 06:42 pm |
I think it is a great upgrade. It proves that the daughter boards are a great idea as it is a reasonably priced upgrade for all. Still playing with it But it now is User friendly Congrats all round
Thanks, the R&D team has been working hard on this
Let us know if you have any other feedbacj
Posted: Saturday Oct 26th, 2013 12:30 pm |
17th Post |
gaynorc
Posts: | 130 |
Can you advise me what my upgrade hardware path would be from the attached jpg of the GSM module which I have. Its currently on firmware 6.081.
ThanksAttachment: 2013-10-26 13.06.52.jpg (Downloaded 94 times)
Posted: Saturday Oct 26th, 2013 12:45 pm |
18th Post |
You need to purchase the GSM4 submodule and a U2 EEPROM 24C256
You can then upgrade the firmware to GSM4 via the intermediate firmware GSM 7.029 as described
Posted: Saturday Oct 26th, 2013 01:13 pm |
19th Post |
gaynorc
Posts: | 130 |
Thanks ident.
Do you know if my module has the IC socket in the U2 position, or whether I will have to solder one onto the board (as happened in a previous post)?
Posted: Saturday Oct 26th, 2013 01:20 pm |
20th Post |
It does not look like the U2 socket has been soldered
You need to solder the 8 pin socket and the shunt for selecting U2/U3 as described in the previous post
Current time is 06:23 am | Page: 1 2 |
