For sending SMS to overseas phone numbers, you should be able to enter the international access code in front of the number, since Comfigurator does not allow the entry of the "+" key
eg
"006512345678" 00 is the international access code (example, may be different for each country), 65 is the Country code for Singapore and the remaining numbers is the phone number
+65122345678 is the preferred way to send SMS messages internationally but Comfigurator does not allow the + key
If you leave out the international access code, eg 6512345678, the SMS will not work
