The current module GSM Interface is UCM/GSM3.
The features of the UCM/GSM3 module include;
- Acts as a backup for dial-out on alarm activation when the land line is faulty or cut. Alternately, it can be used without a fixed telephone line, for installations where a telephone line is not available or not desired. Comfort's dialler can dial to 8 telephones which can include mobile or landline phones, pagers or Central Monitoring Stations.
- Allows the user to dial to the GSM number instead of the fixed telephone line to access Comfort Voice menus.
- Allows Comfort to report alarms to the users cellular phones via text message or SMS. The SMS message will show the alarm type and Zone description as text.eg "101 Back Lane Road - 01 Intruder Alarm - 03 Back Window"
- Allows users to send commands to control home appliances and the security system via SMS, and receive acknowledgement of the command by return SMS.
- Only authorised Mobile phones can send commands and receive messages from UCM/GSM3
Note that UCM/GSM3 is compatible with Comfort II only, and not Comfort I
Important Note:
The GSM network is subject to delays in the voice transmissions which may cause problems in dialing to Central Monitoring Stations which expect very tight limits on the delays between signalling tones. The UCM/GSM3 should not be relied on for the purpose of dialing to a CMS Receiver although it may be used as a backup dialer
UCM/GSM3 Specs- UCM/GSM3 Specifications
- PCB Size: 108 x 88 mm
- Power Supply (Comfort): 12V 50 ma (idle), 250 ma (transmit)
- Operating Temperature: 0-55°C
- Frequency: Quad Band 850/900/1800/1900 MHz
- SIM Card Interface - 3V/1.8V
- Environment: -20 to 75 deg C, < 95 % RH non condensing
Warning
Certain 3G only SIM Cards like "3" three.co.uk in the UK are NOT compatible
Visit the UCM/GSM3 page on the Cytech website at http://www.cytech.biz/gsm_interface.html
