SMS Text excluding Input Names
 Posted: Tuesday Feb 12th, 2013 03:02 am
Howser
I upgraded my UCM/GSM's firmware to 6.081 a while ago, and noticed this morning when I got an intruder alarm that the text sent out to me did not have the input/zone phrase as it used to be,  I got 01 -Intruder-013.
Comfort Version 7.009 (Configurator shows 6.028 as the latest)
 Posted: Tuesday Feb 12th, 2013 03:37 am
The zone and alarm names are taken from the names written to Comfort by Comfigurator
Do a full write to Comfort again after making sure the names ae corect
 Posted: Tuesday Feb 12th, 2013 04:33 am
Howser
I did a full write. The names are correct and were announced accordingly, just the SMS text that did not. The Keypad showed the name as well.
 Posted: Tuesday Feb 12th, 2013 07:48 am
This appears to be the same problem as reported in this thread http://www.comfortforums.com/forum48/3070.html
We have traced this problem. It is due to bug in Comfigurator (up tozs 3.5.6) if the Response Numbers exceed the maximum number (1023 for Ultra) then the Alarm Type Names are written to Comfort with an illegal character in front. When you Read from Comfort, the alarm type names will have the 1st letter missing The GSm SMS messages for alarm types will also be missing This will be fixed in the next release of Comdfigurator (3.5.7 or later)
You may be using Comfigurator 3.5.6 or earlieer
If you upgrade to 3.6.4 and rewrite to comfort then the problem should go away
 Posted: Tuesday Feb 12th, 2013 07:51 am
Howser
ident wrote: This appears to be the same problem as reported in this thread http://www.comfortforums.com/forum48/3070.html
I have been using 3.6.4.0.
 Posted: Tuesday Feb 12th, 2013 08:06 am
Can you send your cclx file to support@cytech.biz
But please do a scan for all modules before that
 Posted: Wednesday Feb 13th, 2013 03:02 am
Howser
Done
 Posted: Friday Feb 15th, 2013 11:00 am
This is a bug that we have confirmed from ULT 7.009 which causes the zone names not to be sent by SMS. ULT 7.014 fixes this and other bugs in 7.009, see http://www.comfortforums.com/forum79/3282.html
 Current time is 02:01 am
