Comfort Automation/ Security System Forums > Products > GSM Module > GSM Module to Replace Landline Functions
 Posted: Tuesday Feb 1st, 2011 05:50 pm
lennyh
I am considering replacing my landline with the GSM module. I would like to see what it can offer by way of functionality. Can the GSM modulereplace these functions?
1. Outgoing phonecalls made by using internal telephones through the sim card installed in the GSM module.
2. In alarmed/ unoccupied mode can the MicroDP2 Doorphone use GSM module to ring out to my mobile telephone connecting me to the person calling on the doorphone?
3. I see in the blurb for the GSM unit that voicemail is not available (as it would be with a landline connection), has this changed or is voicemail still not available. If not are there plans to add this functionality?
4. Is there a method of querying the balance on a prepaid sim card through comfort. This would avoid removal of the sim from the unit to query the balance in a standard mobile phone, then replacing the sim back in the GSM module.
5. Is there a simple way to block out the presence of the landline in comfort to avoid "phone trouble" and other related issues?
Lenny
 Posted: Wednesday Feb 2nd, 2011 12:35 am
See the answers below in red
No, the GSM does not allow phone calls. It takes the palce of the landline for Comfort dial in and dial out only
Yes
That has changed. It now has the voicemail function
No, there is no standard way of doing this. It depends on the operator. A postpaid SIM card ie with a plan would be best as these do not cost much nowadays
Yes, check Disable Line Cut in Modules and Settings
Lenny
 Posted: Wednesday Feb 2nd, 2011 01:02 pm
lennyh
Thanks for the prompt reply. I knew the internal phone dial-out function was pushing it but I am glad to see the voicemail functionaality has been included for this module. This was the main issue holding back purchase.
Lenny
 Current time is 11:48 am
