Comfort Automation/ Security System Forums > Products > GSM Module > GSM not accepting commands from cellular phones declared as VOICE
 Posted: Friday Jan 21st, 2011 09:29 am
ekarak
I have two cellular numbers declared both as "Voice" and "SMS". These numbers cannot control the system by SMS messages .  Is this by design?
 Posted: Friday Jan 21st, 2011 10:12 am
These phones should be able to control the system via SMS. Caller ID must not be blocked on the number. The commands must be within brackets eg (411) which are the numbers to access the control menu, eg 4 for Home Control, 1 for Light and 1 foro ON.
 Posted: Friday Jan 21st, 2011 01:20 pm
ekarak
No, they are not able. checked with similar config on 2nd system, same results.I will PM you the .cclx
 Posted: Saturday Jan 22nd, 2011 05:20 am
attachments are not possible in PMs, please send by email to support@cytech.biz
 Posted: Monday Jan 24th, 2011 01:07 am
We have not received the cclx file
To summarise, to allow the system to respond to SMS commands
  1. The calling phone must be in the phone numbers for dial out
  2. The calling phone must not have its number blocked for caller ID
  3. The GSM SIM of the UCM/GSM must have caller ID enabled, ie must be able to show incming caller IDs. Some plans do not have this feature enabled
  4. The  numeric commands within the open and close brackets must correspond to the user menu numeric commands to control the items selected, eg 4 for Home Control, 1 for Lights, 5 for Master Bedroom Lights. 1 for On, the text message should be (4151)
These are the only requirements to make it work
 Posted: Sunday Jul 13th, 2014 11:17 pm
Swiss-Toni
I have a similar problem, my GSM no longer accepts sms or voice,
If I take the sim card out and put it in a my pad they text messages come through as text messages on pad.
The GSM has worked previously but I noticed on a few occasions when their has been alarm states ect that I as no longer getting texts either.
It seems as though it is a communication error where while the card is in the gsm module it does not receive a signal.
Question is do I purchase a new GSM module with UCM s mine is the older gsm2, or is it a programming error
GSM has the correct numbers programmed to accept texts etc.
 Posted: Monday Jul 14th, 2014 05:05 am
hendy
What is the UCM/GSM firmware version?
Is that UCM/GSM4 ? as described here.
Is there a back-up battery installed?
When the SIM card is inserted it is as though it is a communication error?
What is the LEDs status on the UCM/GSM during this time?
 Posted: Monday Jul 14th, 2014 09:06 pm
Swiss-Toni
The UCM/GSM firmware version is 6.081
The UCM/GSM is the older version GSM2
Backup battery is installed
On the sub module R16 green flashing R13 solid red
On UCM D10 green & D9 flashing
D1
D2 solid red
Busy2 solid red
It would seem to me that the submodule is no longer functioning as it cannot accept commands via text and can no longer be dialed into, I tried another sim card but that did not work either. I do believe that it is a serious communication issue but I am unable to resolve it
I am considering ordering a new submodule which I would rather avoid Since the gsm was bought in 2011 the warranty on it would have run out.
Before I do so I would need to know if it is just the submodule I have to get or or the UCM as well?
 Posted: Tuesday Jul 15th, 2014 05:46 am
hendy
D2 and Busy2 solid red is indicating the module detects no SIM card.
The normal working indication would be Rdy solid green and the other 3 red LEDs off.
Was this UCM/GSM2 working previously?
Can you do a 'Scan for UCMs' from the Comfigurator software?
If the version 6.081 can be seen after scanning that means most likely the UCM base board is fine.
 Posted: Tuesday Jul 15th, 2014 06:50 am
See if the contacts of the SIM card and holder are clean
You may like to upgrade to the UCM/GSM4 buy buying just the submodule. This is a much improved product and it also allows you to check the status on Comfigurator eg SIM card not detected
 Current time is 10:17 am
