Comfort Home Automation/ Security System Forums > Comfort > GSM Module > SMS message Comfort Ultra II - Reporting username
 Posted: Tuesday Nov 3rd, 2009 06:15 am
  PMQuoteReply
rolan
It is not always practical to use voice message in every occassion to learn the name of user who for example armed or disarmed the system.
Is there way to report in SMS message user name along with user id exactly like it works for zones reporting XXXX - Alarm - ZZ Zonename
regards, Rolan
Back To Top
 Posted: Tuesday Nov 3rd, 2009 07:18 am
  PMQuoteReply
The SMS for alarms related to users does report the user number
eg xxxx- System Disarmed - 03 means user 03 disarmed
xxxx- System Armed - 90 means user 90 which is the keypad was used to arm via the one touch keys without any code entered. If a user code was used to arm then the user number 1 to 16 will be reported
For  an alarm related to the module ID , the SMS will be
xxxx- RS485 Comms Failure - 65
where 65 = KP1, 66= KP2, etc 49 = DP1, 50 = DP2, ..., 18 = UCM 2, 19 = UCM 3
This is described in the UCM/GSM Manual
Back To Top
 Posted: Tuesday Nov 3rd, 2009 07:46 am
  PMQuoteReply
rolan
Chiu,
From the manual:
For example, if zone 2 - Kitchen Window causes an intruder alarm, the
SMS message will be
1234 - Intruder - 02 KitchenWindow
where zone id = 2 and userdefined zonename = KitchenWindow
and this works perfectly well
For user in Comfigurator we also have user id selectable from 1 to 16 and also may define user name. However in this case only user id is reported in SMS message. Question is if there is a way, say, in case user= 3 with name= rolan has disarmed the system to send to assigned phones a message with ID & NAME
smth like this xxxx-System Disarmed-03 rolan
rather then    xxxx-System Disarmed-03
Rolan
Back To Top
 Posted: Tuesday Nov 3rd, 2009 10:53 am
  PMQuoteReply
The user names in text are not stored within Comforts memory so it does not report the name.
You can find out the name of the user in Comfigurator
If Comfort is reporting arm and disarm every day then it would not take long to remember which user is which
Back To Top
 Posted: Tuesday Nov 3rd, 2009 11:33 am
  PMQuoteReply
rolan
I am installing the system in pretty crowdy commercial office. No of authorised users will be about 16 and their list may change from time to time as you can imagine. So people would apparently appreciate if we provide the opportunity to read names rather then IDs ...
Back To Top
 Current time is 06:43 am
