It strikes me that with some great new UCMs coming it it would be good if Cytech could produce a new wall mount case designed for mounting lots of UCMs. Maybe even a case with a back plate much like a PCB board; lots of holes where you can screw in different mounting studs to suit the card you are mounting. An analogy is a PC case where you can move the studs to match the motherboard mounting points.
Personally I'd like a case where I could mount say up to 6/8 UCMs and power.
