Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Comfort to RFXCom (X10 RF)
#1
Is there any way of easily integrating Comfort / UCM with these plugin modules ?
http://www.rfxcom.com/transmitters.htm
These are X10 RF modules in reverse - ie they send X10 RF commands to the huge range of devices that are available over Europe. These are immensely cheap to buy and therefore a prime candidate for accelerating home control.
Reply
#2
Got a response back from RFXCom regards connecting their RS232 to a UCM (without being a special UCM)
Because they use 4800, n82 that means the 2 bit stop needs a delay. I understand it is possible for a Comfort ICM to talk at 4800 instead of 9600, but not 2 stop bits. Is there any chance of Comfort\'s logic being able to handle a pause to cope with this ? See below :
\"You have to send 5 bytes for an A1-On or A1-Off
A1-Off cmd to transmitter=> 20609F20DF
http://www.rfxcom.com/documents/RF%20tra...etails.pdf see chapter 10
The delay between each transmitted byte on the RS232 interface must be at least 1 stop bit time = about 2 msec.
Reply
#3
The regular UCM only works at 9600 baud
We have done a special version in which the shunts are used to select baud rate so 4800 is possible
I believe the UCMs actually send 2 stop bits instead of 1. a stop bit is just an idle state so it does not cause any problems with a device that is expecting 1 stop bit, but a device that expects 2 stops bits may not be able to handle 1 stop bit
We shall see if the special firmware can be done as a firmware upgrade using a UCM
Reply
Forum Jump:
Users browsing this thread:
1 Guest(s)
