Jump to keypad page
 Posted: Friday Feb 15th, 2008 09:03 am
garym999
Is there a way to make Comfort signal the KT01 to jump to a specific page?
I'd like the entry response to make the KT01 jump to the keypad page.
 Posted: Thursday Feb 28th, 2008 02:41 am
hendy
One way would be by editing schedule in PICED, open your KT01.ctd project and go to Projects > Edit Schedules... right click on empty field of All Schedules and choose 'Add'. Type the description you want, and under 'Event' select enable by Application 208, add a group with address 130 and description Entry response; select 100% level (ON) and leave the Tag alone (unchecked).
In 'Time' select Repeat every 10 seconds. Make sure everyday is chosen in Day. In Event > C-BUs > Controlled Item select Single Group with Local Network, Application 208, and Entry response Group Address. Still in Event > Page link select Keypad. Click Ok to finish.
Next step will be transfer this setting changes into KT01. Connect RS232 from your PC/laptop to KT01 and set the connector to P4 for programming mode; click "Connect to Unit" under 'Transfer'. To download click on "Transfer to Unit".  After programming, remember to switch back the connector from P4 to P3 for normal operation.
Attached is some screen shots in PICED.
Attachment: Jump to Keypad Page.pdf (Downloaded 10 times)
 Posted: Thursday Feb 28th, 2008 07:48 am
garym999
Thanks Hendy, think I get it, so every 10 seconds the panel looks to see if the entry response is on, if it is it jumps to the keypad page.
First thought would be that 10secs would not be responsive enough in this case. The client will be at the KT01 within this time. Is there any way that the panel can check this response in real time rather than under a 10 second schedule?
Once the alarm has been set it will time out to a welcome page can something be placed on the welcome page to monitor 208, 130 (82h) in realtime?
 Posted: Thursday Mar 13th, 2008 03:52 am
Clipsal have suggested the following method which should work;
Create a dummy button assigned to a group address. This Group address jumps to the keypad page when switched on
In Entry Alert Response, send the Cbus Group address  ON command to the KT01 UCM (This is decared as a Cbus UCM)
 Posted: Thursday Aug 14th, 2008 03:13 pm
garym999
Taken a long while to get back on this but I now have it working.
On the timeout page place a button.
Adjust the visual properties to make it hidden.
Set the page link to the page of yor choice, Keypad in this instance.
Set the remote control tab to Activate component
Set Cbus to status, lighting & group address of your choice.
Now get Comfort to send a CBUS on command to that group during the entry alert and if it is displaying the page that the button is on it will jump to the chossen page in page link. Send a second CBUS off command to reset the keypad ready to monitor the change again.
Note the monitoring button is only active when the page it is placed on is displayed, if you need the action from multiple pages you will need a button per page.
 Current time is 01:56 am
