Comfort Automation/ Security System Forums > Products > KT01 Touchscreen Keypad (OBSOLETE) > KT01 LCD Keypad - Button doesnt work as expected
 Posted: Tuesday Oct 24th, 2006 02:15 pm
Stephen Coates
I have the LCD Keypad, with the standard demo config.
In Control - Lights I have managed to program the top two buttons with toggele
responses that operate outputs (Lighting the LEDs).
This was achieved using Control - 1 and 2.
I then attempted to program the Master OFF button on the control page.
I found that it is configured as 17 in the clipsal program.
Using the same technique in comfigurator I programmed the AllLightsTVOff response.
However when the button is pressed, the outputs are not changed.
 Posted: Wednesday Oct 25th, 2006 12:14 am
adlim
My guess is that the response was assigned in the wrong counter. The group address in the program is in hexadecimal. Hence, it should not be in counter 17, but rather 23 (17 hex).
 Posted: Wednesday Oct 25th, 2006 07:22 am
Stephen Coates
Thanks for the help. It worked.
'more time needed in the manuals, I think'
 Current time is 12:26 am
